GLSL Textured solid : no update of material in 3Dview #31988
Reference: blender/blender#31988
%%%Hi,
since 2.63, I noticed that in GLSL "Textured Solid" the material changes don't show in object mode.
I have to go to edit mode and revert to object mode in order to actualize the changes.%%%
%%%Test file works fine here.
Please provide your system's specifications such as operation system, bitness, video card and video driver you're using. Help -> System Info operator would help you with this. Also specify exact blender version you're using.
And the last thing for now is that there were some fixes which could potentially affect on such an issue were done since 2.63a , so please check if the issue is reproduceable with builds from http://builder.blender.org/download/
Marking as Incomplete for now. %%%
%%%I can confirm it here. I have NVIDIA GM540 on ubuntu 12.04. I also have an optimus system though, may be related%%%
%%%Ah, forgot revision, I have used 48530.%%%
%%%Hi, sorry that I did not provide with that info...Here it is :
Windows7 Professional x64 sp1
Nvidia GTX580 Driver 301.42
Material update in 3Dview (object mode) is okay with versions
r43575
r45265
does not work with versions
r46461:46487M
r46534M
r46561
r48353
r48422
r48514 (so you see, last version still doesn't help with that matter).
Thanks for your hard work !%%%
%%%Reproduced here. Looking into the issue.%%%
%%%Got quick patch for this issue, but that's far away from optimal fix.
Developer note:
The issue is cased by VBOs who're using CD_TEXTURE_MCOL where per-face material settings are stored. This custom data layer is being initialized only once for derived mesh and not updating when material's settings are changing. Current patch forces this layer to re-generate on every draw, which affects on draw speed. Ideally this should happen only when material settings are indeed changes. Would check if it's possible to integrate this smoothly into dependency graph.%%%
%%%Commited patch to svn rev48867.
Thanks for the report, closing now.%%%
