Display RGB not working #32026
Closed
opened 2012-07-06 11:01:20 +02:00 by Pavel Shabanov · 14 comments
%%%Separate RGB-Channels for Display not working. Only preview for track RGB
http://featherfiles.aviary.com/2012-07-06/94101d3dd/f94ec07f204b4ec0bcf91596f3bdc96f.png%%%
%%%Separate RGB-Channels for Display not working. Only preview for track RGB http://featherfiles.aviary.com/2012-07-06/94101d3dd/f94ec07f204b4ec0bcf91596f3bdc96f.png%%%
Author
%%%From the screenshot it's not clear what exactly not working for you. From what i see here is that you've got single blue channel enabled for frame display and it seems this behaves properly (it's difficult to say because depending on colors on the original frame values of blue channels could be different).
Please be more specific and describe what exactly you're doing, what you expect and what you've got. Attaching sample .blend file with a single frame from footage could also help understanding your problem.%%%
%%%From the screenshot it's not clear what exactly not working for you. From what i see here is that you've got single blue channel enabled for frame display and it seems this behaves properly (it's difficult to say because depending on colors on the original frame values of blue channels could be different). Please be more specific and describe what exactly you're doing, what you expect and what you've got. Attaching sample .blend file with a single frame from footage could also help understanding your problem.%%%
Author
%%%Hi, Sergey!
Take a look in the attachment. There's a simple test picture in the Movie Clip Editor and when you will try to see the single RGB channel in the viewport it's nothing happening. RGB working only for track preview, not for the whole frame.
Tested with r48965%%%
%%%Hi, Sergey! Take a look in the attachment. There's a simple test picture in the Movie Clip Editor and when you will try to see the single RGB channel in the viewport it's nothing happening. RGB working only for track preview, not for the whole frame. Tested with r48965%%%
%%%With the file attached here it works fine, but could see some issues with frame update when 2D stabilization is used. Would look into this.
Does pressing reload button in Footage panel helps in your particular case? Also, settings for track preview and frame are totally separated and does not affect on each other which could confuse in some circumstances.%%%
%%%With the file attached here it works fine, but could see some issues with frame update when 2D stabilization is used. Would look into this. Does pressing reload button in Footage panel helps in your particular case? Also, settings for track preview and frame are totally separated and does not affect on each other which could confuse in some circumstances.%%%
Author
%%%yeap, image reload helps)%%%
%%%I've commited fix to rev48749 which makes 3d stabilization works fine. In theory that might have been affected in some other circumstances, so please re-test and lemme know whether it works fine for you now.%%%
%%%We've just discovered other issue with color channels -- it happens when you're using float images (like exr) as a footage, would be fixed soon as well.%%%
%%%That was issue of tomato branch only, which is fixed in avn rev48752. So now please test if it does work for you, because i can't see issues here now.%%%
Author
%%%I test as soon as new build r48752 will appear on graphicall.org
thx a lot
and btw do u know about DPX problem? it looks weird and incorrect http://gyazo.com/61a625426f1ec769a5ebf20b0a375508
I saw the old thread on the bug-traker and just wonder is there any changes with DPX support?%%%
%%%I test as soon as new build r48752 will appear on graphicall.org thx a lot and btw do u know about DPX problem? it looks weird and incorrect http://gyazo.com/61a625426f1ec769a5ebf20b0a375508 I saw the old thread on the bug-traker and just wonder is there any changes with DPX support?%%%
Author
%%%Hi, Sergei
just tested display RGB with r48768 and it's still not working. I grab a videoscreen for a better understaning what's wrong.
https://dl.dropbox.com/u/33481120/movie-clip-editor.avi (15mb)
and there's dissapeared bounding box from object tracks
%%%Hi, Sergei just tested display RGB with r48768 and it's still not working. I grab a videoscreen for a better understaning what's wrong. https://dl.dropbox.com/u/33481120/movie-clip-editor.avi (15mb) and there's dissapeared bounding box from object tracks %%%
%%%That's seems to be a strange version of blender you're using. Are you sure it's a trunk without any other patches?
I'd recommend to test builds from our buildbot service http://builder.blender.org/download/ Seems needed windows builds are already there, linux builds would be ready soon.%%%
%%%That's seems to be a strange version of blender you're using. Are you sure it's a trunk without any other patches? I'd recommend to test builds from our buildbot service http://builder.blender.org/download/ Seems needed windows builds are already there, linux builds would be ready soon.%%%
Author
%%%Thx, with your link everything works perfectly!
I don't know what's wrong with the previous builds from graphicall.org, maybe they're using unsuitable patches.
Anyway thank you very much!%%%
%%%Thx, with your link everything works perfectly! I don't know what's wrong with the previous builds from graphicall.org, maybe they're using unsuitable patches. Anyway thank you very much!%%%
%%%There're lots of branches builds in graphicall, which means revision number could be large enough but needed fixes aren't merged from trunk. Buildbot is always building trunk so we're sure all our fixes are there.
Cool to hear things are resolved for you, so would close the report now :)
Some other notes:
  • Not sure why markers are collapsed for you. This could happen if you've mixed working with newer blender which supports affine tracking and older versions which doesn't. If you'll manage to reproduce this with trunk -- that would be a bug, but i would know steps to reproduce ot.
  • DPX is indeed have some issues. We've got patch which is supposed toresolve most of them, but it need to be updated against current trunk, would take a while. Can't give any feedback on how long it would take..%%%
%%%There're lots of branches builds in graphicall, which means revision number could be large enough but needed fixes aren't merged from trunk. Buildbot is always building trunk so we're sure all our fixes are there. Cool to hear things are resolved for you, so would close the report now :) Some other notes: - Not sure why markers are collapsed for you. This could happen if you've mixed working with newer blender which supports affine tracking and older versions which doesn't. If you'll manage to reproduce this with trunk -- that would be a bug, but i would know steps to reproduce ot. - DPX is indeed have some issues. We've got patch which is supposed toresolve most of them, but it need to be updated against current trunk, would take a while. Can't give any feedback on how long it would take..%%%
2 Participants
Reference: blender/blender#32026
