In the execution result of with_automatic_weight, the difference is seen right and left. #32033
Reference: blender/blender#32033
%%%When Weight is automatically set to Vertex, it is uneven to Weight set right and left.
Mesh used for the confirmation used the one that had united with X axis by Mirror modifier.
It is 2.49b to compare.
The image of the execution result of 2.63.13 and 2.49b is enclosed.
Environment:
windows XP/SP3 32bits
Blender 2.63.13 r48697%%%
%%%Bastien, you're seems to be familiar with wights and armatures. Could you please have a look on this? Thanks!%%%
%%%Hmm… In fact, “automatic” weight (aka bone heat) uses complex math to compute the weights, and this seems to be intrinsically an unstable/fuzzy process (i.e. if you run the operation several times, you won’t get exactly the same results). This is why the symmetry is not respected by default.
You do can get a nice, symmetric weighting with this method (bone heat), but from the Weight Paint mode. Once parented to armature:
Now you will have a symmetric weighting, because the WeightPaint editor by default has its X Mirror option enabled. If you disable it, you’ll see you get again uneven weights…
Think I’ll just add the "X mirror" option to the parent operator, and that will do it ;)%%%
%%%Done in 48941. Thanks for the report.%%%
%%%The result of the confirmation by the following versions is this.
Ver2.63.14 r48988
If the result is slightly different extent every time it executes it, it is possible to understand.
However, isn't the indicator that it is necessary to select any necessary as long as?
%%%The difference seems not to be generated right and left without using the option of added X Mirror.
I think that a phenomenon here is more interesting. %%%
