Collada import when nodes share geometry but not material #32240
2 Participants
Reference: blender/blender#32240
%%%When a Collada file contains several nodes which link to the same mesh but each node has it's own material then on import the materials are not created as objects for each node but as shared data for the mesh. Which leads to all nodes having the same material(s) now instead of each node having it's own.
I have attached 2 examples. The first one is a Collada file with 2 cubes which I exported in Irrlicht (a patched version) which pretty much just contains the minimum to reproduce the problem (+ a screenshot to show how it should look like).
The second example is a .blend file which looks pretty similar. To reproduce it with that export it as Collada and then import that Collada file again.
%%%A forgot to write ... the system this was tested on was Blender 2.63.0 (r45996) on Windows 7.%%%
%%%In the standard Collada data there is no way to distinguish between materials assigned to Geometry and materials assigned to Object. Therefore Blender inserts the materials based on the user preferences (yes, you can specify if you want materials to be automatically assigned to Object or to Data).
I tested this and i found that while it works in principle there is still a bug which breaks the material settings. For the "2 cubes testfile" the first material is correctly assigned to the object while the secnd material is assigned to the mesh and the secnd object gets 2 material slots. I am working on that.
I am also thinking about doing some test to determine where the materials have to be bound:
if user preferences are: assign materials to data
else
end
Does that make sense ?%%%
%%%@Sergey: i just added the files:
shared_mesh_multiple_mat.blend
shared_mesh_multiple_mat_reimported.blend
To reproduce the problem:
i use trunk version 49795%%%
%%%I believe that set_mesh() does some wrong assumption...%%%
%%%The attached patch fully solves the import issue without any know restrictions.
@any senior developer: Please can you check if the solution is correctly implemented.
Any hint for improvement or an easier (fully working) solution is very appreciated :)%%%
%%%Committed in revision 49847%%%
