Copy colors does not work properly (V value wrong range in Color Balance Node) #32418
2 Participants
Reference: blender/blender#32418
%%%Hi,
I tried to copy colors from property panel (material tab) to Color Balance Node and noticed a different result. I assume it is the V value in Color Balance Node which is 0-2 instead 0-1.%%%
%%%I noticed the same for the Hue Correct Node.%%%
%%%Fix in svn, thanks for the report.%%%
%%%Hi Brecht,
I still get different results when copying colors in the color input fields of the 'Color Balance' Node. For example if I copy a RGB (0,5 0,5 0,5) in one of the three 'Color Balance' Node input fields I get there an RGB (0,736 0,736 0,736).
Maybe I do miss some background knowledge here about that node but why is the range of the values between 0-2 instead 0-1? This seems to be only here and by the 'Hue Saturation Value' Node the case (here only for the S and V value) not the Hue Correct Node as wrongly said in message #1.
When I talk about a range between 0 and 1, I mean when I use the color input fields as slider by just using the mouse. It is of course possible to directly type in larger values then 1.%%%
%%%I corrected the copying when you go over the color box, press ctrl+c and then do ctrl+v over another.
The values are indeed different, and that's because they are in different color spaces. The material colors are in scene linear color space, while the color balance values are not really colors by themselves, they are parameters for color correction.
If for example Gain was limited to 1.0, you could only use the slider to make the colors darker, not to make them brighter since that requires values > 1.0. So it makes sense to have different default limits because they are used quite differently.%%%
%%%Ok thanks for the explanation, learned something new today.%%%
