Segmentation fault when moving bone in pose mode when Ghost Around Frame is enabled #32440
2 Participants
Reference: blender/blender#32440
%%%Hello,
With current svn and 2.63a, only linux64 :
Get the .blend files ( in the same directory ).
Open exercice1.blend. Ball is linked from ball.blend, with proxy on rig.
Up the Ghost arround Frame from 0 to 1
Move the bone ( press G --> Object moving to origin. Move mouse --> Core dumped )
Regards,%%%
%%%Program received signal SIGSEGV, Segmentation fault.
0x00000000017b80cf in constraintTransLim (t=0x68c28d8, td=0x6384a48)
2162 if (con->flag & CONSTRAINT_DISABLE) continue;%%%
%%%From my investigation so far, it looks like the final BKE_pose_rebuild() (under "restore" in draw_ghost_poses()) is at fault here, since it results in the constraints pointers pointing to bogus locations. However, still need to double check if there are other consequences instead now... %%%
%%%Ok, this fix seems to work well enough in tests I've done so far. Fixed in svn.
Thanks for the report!%%%
%%%Hello,
Problem still occurs with files I attached !%%%
%%%Weird. I tested/devised the fix with your files, and cannot reproduce here anymore.
Try updating again and send in a backtrace showing what's going wrong now.%%%
%%%Hello,
From my svn update it's still KO, but seems to be OK from a fresh build. Sorry about that :-/
Thanks for this fixed !%%%
