bmesh: selection state of vertices not always correct #32446
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
2 Participants
Reference: blender/blender-addons#32446
%%%r50265
This is about a bmesh constructed from a live mesh via bme = bmesh.from_edit_mesh(object.data)
bme.verts[some_index].select is not always true to the selection state as it should be.
If the mesh is in edge select mode and for example an edgering of edges is selected then all the vertices contained in those edges should have vert.select = True
This is the case most of the times.
However if first the edgeloop is selected and then one edge on the border (or end of the loop) is deselected
then both vertices contained in that edge have vert.select = False.
Even though one of them should still be True since the neighboring edge (from the edgeloop) is still selected.
I hope this explanation is clear enough.
%%%I found a way to redo and fixed that case now, but it involves undo. It's not clear to me if that's the same bug you found, if it's not please give exact steps.
If you are doing the selecting/deselecting using a script, be sure to use .select_set(..) functions rather than setting .select directly, only the former will automatically do vertex/edge/face selection syncing.%%%
%%%It seems to be fixed. thanks.
It is very probable that it was that undo thing.
I was repeatedly testing my script which is working on the selection
undoing a lot in the process of selecting executing and so forth.
but it is working now. %%%
%%%Great, thanks for testing, closing report then.%%%
