iTaSC fails in very simple stretching case #32770
2 Participants
Reference: blender/blender#32770
%%%I appended a very simple rig with four bones. Two of them are stretchy bones which don't rotate but should stretch to reach the "target" bone. The legacy solver does fine in this case. But with iTaSC no stretching occurs at all. If you go trough the 50 frames of this example then you should see that iTaSC does not stretch the bones as desired. If you switch to the Legacy solver then it behaves as it should, even so there are some angles in which it does not.%%%
%%%PS: I appended a second file in which i enabled rotations, but set the stiffness to the maximum value. In this case iTaSC behaves correctly. It gives me the impression that iTaSC "thinks" that the task is impossible to solve without rotations (rounding errors -> wrong assumption) and stops iterating before a close solution might be found.%%%
%%%Fix in svn, thanks for the report.%%%
