Crash when Exporting to Collada file (.dae) #32784
Reference: blender/blender#32784
%%%Blender crash and exit when I try export ANY project to Collada file (.dae). It always repeated.
My system data:
Windows 7 Home basic,
Radeon HD5145 videocard
Blender 2.64 and Blender 2.63, both.%%%
%%%Gaia, could you please check this report? Thanks!%%%
%%%Please can you be a little more specific ?
I have no troubles with exporting to Collada,
neither on blender 2.63 nor on blender 2.64
Can you provide an example blend file please ?%%%
%%%I did simple object and try it export in .dae. Crash again... For example, no problem export to .3ds others I am not use. I use Google SchetchUp, so I like using .dae formatted
files. Also, assets exported from SchetchUp, when imported in Blender, lost some important parts. It seems only integer objects can be imported from ScetchUp. Not connected objects, but still present in model,are lost in import process...
Simple file I attach here (when I try export it in .dae blender crash again...), hope it will loaded,here little strange system...%%%
%%%I know it's frustrating and I don't dispute that you have the reported issues.
ut we can not reproduce your issue with the given description and data.
In this bug tracker however, we expect users to present cases that are redoable,
and only then we can work on them.
Here are some hints how you can proceed:
%%%Blender on my computer also crashed when I try to export any collada file to the directory "D: \ Germano \ Acadêmico \ 7 º Periodo \ PLANEJ URBANO E REGIONAL I \ Trabalho da angela \ periodo final \ cotas ".
However when I exported to the "desktop" or drive "C: " or "D: " export worked.
Must be because of the "^" and "º" in the directory.
I had a Note Core i3 4GB HD 500GB %%%
%%%I can't use another system, because own just one machine. I no invent any new method to export, just use Blender menu. Wow! I try to save in just drive D: and it works!
It really impossible save in directory, for example like D:/3d/Ferrari project/ferrari-enzo.dae . It look like one similar problem, which just described above by Gemano Cavalcante.%%%
%%%I can confirm that the export crashes when special characters are used in the export path.%%%
%%%What we can do further? Do you resolve this issue yourself? Do you need ,Gaia, something else?%%%
%%%Fix was committed it in revision 51185
Please test the fix and report back if your issue
is not solved.%%%
%%%Your reported issue has been fixed in SVN. Thanks for taking the
time to report!.%%%
%%%Sorry, I can't find this revision 51185, here is link to https://svn.blender.org/svnroot/bf-blender/trunk/blender/ but there only bf-blender - Revision 51190: /trunk/blender
So where it is? Can you give point where it lies?%%%
%%%You can use any later revision than 51185. 51190 should be fine :)%%%
%%%Ohou...There so much everything,what files I need to take and change for improve export-import? Here still is troubles with others formats... Thank you.%%%
%%%I do not exactly understand your question. You can get ready made downloads of Blender from Graphicall.org Here is the link for 64bit Windows versions:
http://graphicall.org/64bit/trunk/optimized/blender/windows
Be sure you download a version with revision > 51185.
Right now while i type this post, there are 2 builds which contain the Collada export fix.%%%
%%%Thank you, Gaia. I found later than 51185 svn. It have no russian lang support, but it really not so important, as I can read both eng and ru. Most important, it package
have no import-export Collada .dae. But instead it export TRUE formatted file .3ds, which I also can import in Google SketchUp and work with it. My last Blender version export .dae .3ds files, which loaded in SketchUp with holes(!!!). This version export true file which can be proceed.
But all this still little not useful...
And. I found nothing better than Blender for now. I wish do animations and games and just models, as I am still artist, so Blender really great thing!%%%
