No SSL Support in official linux distributions of Blender ? #33102
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#33102
%%%Hi.
I have created an Addon that internally makes use of the https connections to the Internet. This Addon works great as long as i run Blender on Windows (i tested on Windows 7) The Addon fails on Linux. It looks like the problem is that for Linux blender is distributed without SSL support.
The attached code fails on line 42 and raises the exception on line 49 when called with a "https://..." URL. The given reason is:
This code works with Blender releases on windows, but fails on linux. Here is what i got as environment specification from the user:
Linux: linux Mint 13 KDE 64-bit
Blender 2.64.0 - r51026 [downloaded from blender.org]
64-bit version %%%
%%%It always helps when reporter strips their full addons to minimal script which demonstrates the particular issue. It seems you even don't have entry point to this script.
Here's the script i've tested:
import urllib.request
response = urllib.request.urlopen("https://svn.blender.org/svnroot/bf-extensions/")
print(response.read())
response.close()
This worked nice in 2.64, 2.64a, current buildbot (both glibc2.7 and 2.11).
Please provide minimal script which demonstrates the issue. So far everything works smooth here.%%%
%%%Managed to redo on fresh linux mint. Checking if it's our fault or something to be configured on the system.%%%
%%%>>> import ssl
ImportError: libssl.so.0.9.8: cannot open shared object file: No such file or directory
My systems ssl is /usr/lib/libssl.so.1.0.0%%%
%%%The issue has been fixed in builds from builder.blender.org and it should be fixed in upcoming 2.65 release as well.
Thanks for the report, closing.%%%
