Text Font Bug #33163
Reference: blender/blender#33163
Category: Rendering
%%%If you enable wire shading on a material and you run the file with the BlenderPlayer the font text don't will be displayed correctly.
The embedded player working correct.
Tested on Windows XP 32 Bit with
Blender 2.59 not working
Blender 2.62 not working
Blender 2.63a not working
Blender 2.64a not working
Blender 2.64.9 r52065 not working%%%
%%%I fond out why this happens. in the GPC_RenderTools.cpp there is glPolygonMode(GL_FRONT_AND_BACK, GL_FILL) in RenderText3D.
I have attached a patch.%%%
%%%The patch seems ok, but what effect do you expect when using wireframe in a text object?%%%
%%%A user from the Blendpolis forum uses a box in wireframe mode to get a outline around the selected menu text.
I attached a new file where you can see the effect in the blenderplayer if you move the mouse over the text.
A other uses the wireframe mode for displaying the weapons as wireframe in the weapon select menu.
But without the fix the text also render in wireframe in the blenderplayer.
%%%I don't want to render the text in wireframe. I want to render it filled like in the embedded player.
Sorry if I confused you with my second post. What I want to write was.
In the GPC_RenderTools.cpp there is glPolygonMode(GL_FRONT_AND_BACK, GL_FILL) in RenderText3D missing.
%%%I talked with Diego Borghetti (blf mantainer) and he said the patch is ok, but it should add a glGet before changing it to restore the polygon mode state after the text is drawn.
At first I thought he may wanted to handle this inside BLF, thus the delay in the review.
Can you do the above changes? Thanks%%%
%%%I'd try to avoid glGet if possible. It slows things down and I've been trying to remove all uses of it in the BGE. Maybe use glPushAttrib instead? However, that might be deprecated.%%%
%%%I have now written two new patches one with glGet and one with glPushAttrib. So you can choose the patch you like.
I've been looking into the source code and found both commands.
The command glPushAttrib works up to OpenGL 2.1 and does no longer exists in OpenGL 3.0.
But I think that it is unnecessary to store and restore the value, because the font object is at the end of the render loop in front PostRenderScene call.%%%
%%%The embedded player doesn't bother with attempting to restore the previous state, so the Blenderplayer shouldn't either. Although, looking at KX_BlenderGL::DisableForText(), it looks like the Blenderplayer is also not disabling the following: alpha blending, alpha testing, lighting , and color materials. I'm thinking the solution should be to copy the code from DisableForText() and put it into GPC_RenderTools::RenderText3D, so the two RenderTools are identical in this aspect again. Fairly soon I plan to get both players onto a single RenderTools (or drop RenderTools and merge it completely into the rasterizer), but until then, we might as well get this bug fixed.%%%
%%%I don't added KX_BlenderGL::DisableForText() the other disable for alpha blending, alpha testing, lighting and color materials, because so the user can decide if he want to
render the Text shadeless or not.
My suggestion is to remove the disable calls from the KX_BlenderGL::DisableForText() to, if it doesn't makes any other problems.
%%%I've committed your fix of adding glPolygonMode(GL_FRONT_AND_BACK, GL_FILL) to GPC_RenderTools::RenderText3D as r57623. I did not commit any of the glGet/glPushAttrib code as I think this is unnecessary and just slows things down. As for copying more of the disables or removing them from DisableForText(), I think that is better left for after the next release (we're supposed to only be doing bug fixes right now).
Thanks for the fix!%%%
