Hotkey changings between 2.63 and 2.64 problem #33227
Reference: blender/blender#33227
%%%r52207, Win 7, 64 Bit
I stumbled across some changings in the hotkeys between 2.63 and 2.64. And they make trouble now because i have very heavily modified user preferences.
When a new version appears you can choose in the splash screen to use the old configuration. I did this, and some of my hotkeys didn
t work anymore then. Shouldn
t Blender warn me about changings in the hotkeys when using the old configuration? Ideally telling me at which items the changings happened so that i can fix them one by one?The bug here is that Blender should at least transfer existing hotkeys. Which didn
t work here for camera and my custom hotkey "Numpad ," for it. It jumped back to the standard "Numpad 0" hotkey. And blocked the other "Numpad 0" hotkey by that, which i had connected to View Selected. Same goes for the Set 3D Cursor, which i had connected with "Alt+Action mouse". It jumped back to the standard "Action mouse" only hotkey, blocking now my Action Mouse action to move the view with right mouse button. And i don
t know which hotkeys are back at default settings too. Time will tell.Attached the whole 2.63 folder from my Appdata path, including the default.blend. That way you should be able to load this old configuration into Blender 2.64 and compare it with 2.63. As told, i had switched the View Selected with the Camera View button. So that one`s easily comparable. I rarely use the Camera View, but heavily the View Selected. And the zero button is the bigger button ...
And attached is a screenshot from two things that are different now between the versions. What is the second View Selected entry good for?%%%
%%%This is not always possible to copy hotkeys from older version to newer -- for example in cases when oeprator's properties were changed (and some operators' properties were changed from 2.63 to 2.64). So in general it's not always solvable. Maybe could be done something with your particular cases.
Brecht knows this area much better than me, so will assign to him.%%%
%%%Thanks Sergey :)
Yes i know. I stumbled across it because some of my hotkeys turned disfunctional. As told, to have at least a warning would be nice. A hint that this and that hotkey could have stopped working because of internal changings. I cannot see those changings. What i see is that my hotkeys stops working.
Things would be much easier when Blender would have a proper hotkey tool that tells me for example when a hotkey is already in use by another tool. Or when the search function in the hotkey panel would really work in an useful way. But it even misses items in the same section. Search for numpad to see what i mean. As it is now maintaining hotkeys is a pain. Even without the jumps between the versions that mixes up the hotkeys then.%%%
%%%Fixed the keymap syncing in the cases mentioned here. Further, we know the keymap editor can use improvements, but that's outside of the scope of bug reports.%%%
%%%Guys, you have a great hot keys editor! It's UI + abilities to "hotkey" almost everything is very handy.
On my new job I've start to adapting 3dsMax's keymap to Blender's... It's not good there if to say polite.
Daz3D - simply awful... like preferences in MS Word.
SolidWorks - one key can be used only for one operation.
Blender beats them all! Because you allowed to choose the same keys between different modes and editors inside Blender.
If I could measure a "readiness" of different parts of Blender then it's keymap editor gets ~99% IMHO
Some little things like these only shows that you make a constant and quick progress to Blender.
Thanks a lot!%%%
