Cycles to the nodes. Regular close Blender in editing. #33327
Reference: blender/blender#33327
%%%Hello,
Excuse me for poor english.
I use Blender 2.64.0 r51232 and cycles to the nodes.
I use Ubuntu 12.04 LTS 64 bits:
Linux geeks-To-be-filled-by-O-E-M 3.2.0-33-generic #52-Ubuntu SMP Thu Oct 18 16:29:15 UTC 2012 x86_64 x86_64 x86_64 GNU/Linux
The log report this error:
Nov 27 20:46:58 geeks-To-be-filled-by-O-E-M kernel: [ 1876.534111] do_general_protection: 39 callbacks suppressed
Nov 27 20:46:58 geeks-To-be-filled-by-O-E-M kernel: [ 1876.534115] blender[14669] general protection ip:d708f0 sp:7f22e0ffbc00 error:0 in blender[400000+3f2e000]
Nov 27 20:52:47 geeks-To-be-filled-by-O-E-M kernel: [ 2226.006687] blender[15823] general protection ip:d708f0 sp:7f2510bfec00 error:0 in blender[400000+3f2e000]
Thanks you.
%%%I don't understand this report... are you saying Blender is crashing when you edit nodes? Then we need a .blend file and the steps to redo the crash. It can be difficult to figure out which steps exactly make it happen, but there's really nothing we can do unless we have that information.
The error log unfortunately doesn't give us information we can use.%%%
%%%Are you saying Blender is crashing when you edit nodes? -> Yes, this exactly this.
when I change my compositing nodes it is that the crash occurs. It is therefore necessary to recalculate the image and then redo all the nodes.
I ask a colleague if he had the same problem and this is exactly the same with the same version of Blender.
For your information, I forget to add that I turn on two GTX580 card.
I've made the commitment problem file.
Thank you.
%%%I tried rendering and then editing the nodes in this file for about 5 minutes, but it didn't crash for me. Maybe it's a specific operation that crashes, we'd need to find that out.
You could also try the 2.65 test build, there have been some compositing fixes since 2.64 which might have solved this:
http://download.blender.org/release/Blender2.65/
Also by the way, you can use "Save Buffers" in the Performance panel for rendering, and the after a crash or blender restart run "Read Render Layers" in the node editor to get the rendered result. Not a real solution for the crash but for heavy renders it can be nice to enable this.%%%
%%%Bonjour,
Je viens de tester la manipulation "cocher Save Buffers" puis j'ai repris le travail des nodes.
Lorsque j'ai fait comme sur la pièce jointe, Blender à fermé. Voila ce que le retourne le log:
Nov 28 07:18:18 geeks-To-be-filled-by-O-E-M kernel: [ 937.670855] do_general_protection: 39 callbacks suppressed
Nov 28 07:18:18 geeks-To-be-filled-by-O-E-M kernel: [ 937.670859] blender[6325] general protection ip:d708f0 sp:7f2694ffac00 error:0 in blender[400000+3f2e000]
Je profite pour vous envoyer le fichier généré en /temp/ "DDWE exercice éclair 4.blend_Scene_RenderLayer.exr" et le "2762.blend" correspondant.
Je testerais dans la journée la version 2.65 sur mon poste en espérant que ce soit résolu. J'espère que votre analyse conjointe des fichiers et la correspondance avec mes logs permettrons à une plus grande stabilité.
Toutefois, j'ai peut-être mal utiliser les nodes et c'est peut-être aussi la raison du plantage. Auquel cas il serais peut-être intéressant de faire apparaître un message d'erreur pendant le groupement de noeud avant de lancer un render. A ce moment là, Blender ne fermerais plus systématiquement.
Merci beaucoup.
Courage à l'équipe qui se démène pour nous, utilisateurs.%%%
%%%Hello,
I just tested handling "check Save Buffers" then I resumed working nodes.
When I like the attachment, Blender closed. This is what the log returns:
I take this opportunity to send the generated file / temp / "DDWE year 4.blend_Scene_RenderLayer.exr Flash" and "2762.blend" correspondent.
I testerais in the day the version 2.65 on my computer hoping that this is resolved. I hope your joint analysis of files and correspondence with my logs allow for greater stability.
However, I may be misusing nodes and it may also be the reason of the crash. In which case it would be interesting to show an error message during the group node before starting a render. At this point, Blender would close more systematically.
I am not come to make attachments. I propose you a zip file containing the image and files. http://dl.free.fr/pOLM2M7zZ
Thank you very much.
Courage the team struggles to us users.%%%
%%%I can not reproduce the crash here on Debian with neither 2.64a release nor current trunk.
Couple of notes and questions:
Anyway, please provice system-info.txt generated by Help -> System Info operator, provide hardware and OS information.%%%
%%%Ok to do other tests, this prduisant not always the same way with the same nodes.
So, I'm back on the info.txt file-system. Here it emerges. Available file attachment.%%%
%%%We just had another bug report about a compositing crash, with a glare node:
http://projects.blender.org/tracker/index.php?func=detail&aid=33338&group_id=9&atid=498
This node setup has two glare nodes, so it the two may well be related. I'll test this bug on a few other operating systems later, hopefully I can redo the bug then.%%%
%%%Hello,
It's cool that you find a case similar to mine. I proposes to continue to look for cases where this type of bug occurs particularly in tests.
Thank you very much for your tests and opportunities to reduce the problem in future versions.%%%
%%%I've checked the file with valgrind and can not see any reports from there.%%%
%%%Hello,
If I understand correctly, with the current data file and it is not possible to reproduce the bug. In this case, what would change in the Glare or Compositing between version 2.63 and 2.64? Is there a track that SOTE there?
Thank you very much for your input, I understand it is quite difficult to find a random bug and then is not proven from files provided.
I still listen to whether to provide further guidance.%%%
%%%New compositor system was implemented in 2.64, that's quite a lot of changes ;)
From your system-info.txt i could see you're not using official build of blender. There could be some misconfiguration in build environment (like bug in gcc's openmp we suffered a lot before). So please, test f builds from http:*www.blender.org/download/get-blender/ or from http:*builder.blender.org/download/ crashes for you.%%%
%%%Pourtant j'ai utiliser le Blender que vous m'avez linker. À savoir un .zip que je décompresse et que j'utilise tel que. Je ne fais aucune compilation.
Est-ce peut-être la source du problème. Il faudra donc confirmer.
Quoi qu'il en est je re télécharge la dernière version 2.64a du premier lien. A voir par la suite si je rencontre le même souci.%%%
%%%But I use Blender you gave me linker. Namely one. Decompresses zip I use and I like that. I make no compilation.
Is this maybe the problem. It will therefore be confirmed.
What is it I re download the latest version 2.64a of the first link. To see later if I have the same concern.%%%
%%%I've prepared linux 64bit debug build of blender which you could download from http://download.blender.org/ftp/incoming/linux-glibc211-x86_64.tar.bz2
Please download it, unpack, install gdb (sudo apt-get install gdb) and then:
This steps will help a lot troubleshooting the issue.%%%
%%%I try to do the manipulations.
gdb already installed.
@-To-be-filled-by-O-E-M:~$ sudo apt-get install gdb
[sudo] password for **:
Lecture des listes de paquets... Fait
Construction de l'arbre des dépendances
Lecture des informations d'état... Fait
gdb est déjà la plus récente version disponible.
Les paquets suivants ont été installés automatiquement et ne sont plus nécessaires :
Veuillez utiliser « apt-get autoremove » pour les supprimer.
0 mis à jour, 0 nouvellement installés, 0 à enlever et 13 non mis à jour.
By cons Blender is not started.
@-To-be-filled-by-O-E-M:~$ cd /home/geeks/debug_blender/linux-glibc211-x86_64/
@-To-be-filled-by-O-E-M:~/debug_blender/linux-glibc211-x86_64$ gdb ./blender
GNU gdb (Ubuntu/Linaro 7.4-2012.04-0ubuntu2) 7.4-2012.04
Copyright (C) 2012 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later http://gnu.org/licenses/gpl.html
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law. Type "show copying"
and "show warranty" for details.
This GDB was configured as "x86_64-linux-gnu".
For bug reporting instructions, please see:
http://bugs.launchpad.net/gdb-linaro/...
Reading symbols from /home/geeks/debug_blender/linux-glibc211-x86_64/blender...done.
(gdb)%%%
%%%at this point you need to type: run
It should launch blender. Then make it so blender crashes. Switch back to the terminal and type: thread apply all bt%%%
%%%So this is what it has given me.
http://www.pasteall.org/37643%%%
%%%This is still ok -- gdb shows threads are creating and finishing.
What you need to do is to run blender in gdb for until it crashes and as soon as blender crashes get a backtrace using "thread apply all bt" command in gdb and pasteall this backtrace.%%%
%%%I try to "thread apply all bt" without success. Interface planted.
I had to reopen a new console to do a "ps-A | grep blender". Then "kill -9 [num_tread]."
I have not been able to capture more. I'll still try to re case I missed something. If necessary, I will ask for help to see what happens.%%%
%%%Did you try running blender in a windowwed mode, so you could see both console and window at the same time?%%%
%%%Yes, it is. I see both at the same time.
I got to finish the planting and tread with a return error:
http://www.pasteall.org/37644
I suppose I should continue.%%%
%%%Ok, it gives some clues. Will check on them and report back.%%%
%%%I'm glad I put a 0x ... this window that shut only from time to time. I take my work confident for the next update.
Thank you very much for your patience and tracks to try the command line. I do not know how this process but it is nice to know that it exists.
I keep the subject in case I détecterais a similar case involving the nodes.
Soon.%%%
%%%Think i've found one place which could lead to crash. Working on a fix now. Hopefully it's exactly the same culprit which cases this issue :)%%%
%%%Merci pour ce correctif à venir et pour la rapidité de votre réponse.%%%
%%%Commited fix to svn rev52679. which should arrive to http://builder.blender.org/download/ soon. Please test this revision and say if crash is fixed for you now.%%%
%%%Hello,
I just tested the SVN version. I restart a F12 to preview to work with nodes. At the end of the generation of the image, the screen was frozen.
Here is what I have been back in the console:
http://www.pasteall.org/37655
For me, the bug is not solved if a simple renderer compositing mode crashes Blender. That back to what was explained in another post http://projects.blender.org/tracker/index.php?func=detail&aid=33338&group_id=9&atid=498
I hope this new track will fix this bug in future versions.
But thank you for your involvement in the search for this bug.%%%
%%%Was my mistake in initial patch. Should be fixed in svn rev52681. It'll be available at http://builder.blender.org/download/ soon, please test it and report back :)%%%
%%%Guy from other compositor crahs report confirmed there's no crash here. Very likely your issue is solved as well. Will mark a report as solved now.
Feel free to poke me here if issue still occurs for you.
Thanks for the report and now closing it :)%%%
%%%En effet, bien vue ! Je n'ai pas relevé de bug concernant le glare, le F12 et le comopositing durant le fonctionnement de cette dernière SVN :)
J'ai poussé le vice jusqu'à 3 génération de glare, les un derrière les autres et combinés entre divers branches de glage. Niveau 2 -> glare type 1 -> glare type 2 -> add 1 -> out | et | Niveau 2 -> glare type 1 -> glare type 2 -> glare type 3 -> filter -> add 1.
Blender n'a pas fermé brusquement :)
Pour preuve, je n'ai plus que des tread en sortie : http://www.pasteall.org/37661
Je suis vraiment content d'avoir contribuer à l'amélioration et la trouvaille de ce problème. Merci aussi pour votre correctif qui sera dans la prochaine sortie. J'ai hâte de tester la version stable.
Bon courage pour la suite des résolutions de bug. Et merci une nouvelle fois pour cette expérience enrichiassante.
Alex.%%%
