Bevel Tool issues #33714
2 Participants
Reference: blender/blender#33714
%%%This is the mesh tool and not the modifier.
The bevel tool has a variety of issues that I will now list and describe to the best of my abilities.
The bevel offset is inconsistent between angles of a mesh. The setting can often be radically different on a vertical edge compared to a horizontal edge. I believe this might be related to scaling, since often its a mesh object that has been duplicated in edit mode, connected via bridging and the the edges give unpredictable results.
Often the bevel tool ends up just creating a subdivision along a plane around the edge rather then a true "rounded bevel"
I experience inconsistent (but repeatable) crashes when using the bevel tool with the repeat last command.%%%
%%%I can look at this, but I need more details about how to repeat these. It would be best to attach a .blend that, upon beveling, exhibits the problems you are reporting. Thanks.%%%
%%%http://www.pasteall.org/blend/18516
This .blend illustrates issues 1 and 2.
And 1,2 and 3 can be replicated by doing the following:
(world settings are configured to metric) Perform a bevel on the bottom edges of model on the left with .300 offset and 6 segments. You will see the flat-like "bevel" on the first model. (problem 2) Select the same area on the model rotated on the right. Click repeat last command. (this illustrates problem 1 and the scaling change of the bevel using the same settings.) Next select any area on either meshes and click repeat last command. (Blender will crash.)
%%%Thanks for the .blend. I can repeat your issues and will now look at how to fix them.%%%
%%%The problem is indeed related to scaling. The objects in the example blend are scaled by 0.135 in the Z direction, and 1.0 in X and Y. The bevel is uniform and round on the unscaled object, but then the scaled object looks flattened. A workaround until this is fixed would be to apply the scale transform (in the Object menu) before beveling.
But I agree that bevel should probably work as you expect without such a workaround. I want to consult with other Blender developers about the best way to do that. One way would be to pass in the X, Y, and Z scales to the bevel operator and transform the coords by those before the calculations that place vertices, and then transforming back, but this seems messy; maybe there's a better way. (By the way, fixing this would also fix another user complaint, which is that the 'offset' number isn't actually the offset in Blender units if the object has been scaled.)
The crash is a separate problem; I haven't fully debugged that yet.%%%
%%%OK, Sorry, but the consensus among Blender developers is that the flattening issues (1, 2) are "working as intended" -- that is, the bevel is supposed to work on the untransformed object. The other tools work this way too (e.g., "inset faces"). You need to apply the scale transform before beveling if you want the bevel or other tools to operate with measurements on the transformed object.
The crash on repeat problem has been fixed in svn rev 53532. Thanks for the report and example for reproducing it.
