Cycles TS Normal map shading not same as BI viewport #33830
Reference: blender/blender#33830
%%%windows 7, GTS 250
r53476
If you bake a tangent space normal map in blender internal, it displays perfectly in the textured GLSL viewport, which is good, but when the same normal map/object are used with cycles, flat areas have some artifacts. The attached image shows the comparison (ps I did select non-color data on the image texture node)
%%%Please respect our bug reporting guidelines.
I know it's annoying to see errors, but to be able to fix things, you have to help us by providing an example that gives others the same errors.
The fact glsl shows things different than render code is normal to expect. each system does things differently...%%%
%%%Ok sorry, I've attached a blend file. I've also attached the normal map png because the packed png doesn't seem to work in cycles unless the image is saved externally (maybe a bug?)
Ps I thought it might be something to do with triangulation but it still looked wrong when I tried with a pre-triangulated mesh.%%%
%%%Fix in svn, thanks for the report.%%%
