Differences in render passes progressive/non-progressive #33838
Reference: blender/blender#33838
windows 7, 64 bit, NVIDIA GeForce GTX 285
2.65.8 r. 53 729, tested also in official 2.65a
If I render separate passes with progressive and non progressive integrator I get differences. On a side note - as far as I can compare, I should get the same results with noise (mesh emitter, no background MIS, all samples in non-progressive set to 1) and same amount of passes, but still I get better result with non-progressive, but that's probably the result of differences in passes.
Just render the attached scene first with progressive and then without it and see the difference in passes. It should work with pretty much any scene with glossy and transparent shaders. I marked some of the most visible differences in the attached image.
%%%Hi,
I experienced the same before, this is indeed interesting.
I am not exactly sure though if this is a bug, the final image converges into the same result.
The difference in the passes could be related to the different sampling techniques. What do you think Brecht? %%%
%%%The difference in noise is intentional, this is because the non-progressive integrator will sample all light sources once for each AA simple, rather than picking a single light source as the progressive integrator does.
The passes are indeed wrong though, will look into a fix.%%%
%%%Fix in svn, thanks for the report.%%%
