RGB and HSV values inconsistency #34079
Reference: blender/blender#34079
%%%winxp 32 bits,
Split the viewport
Have the Texture Paint mode in one window and have the UV/Image Editor in another
In the UV/Image Editor click on Image -> New Image
Change the color of that new image so it has the RGB values R : 0.2 , G : 0.2 and B : 0.2
Now go to the Texture Paint viewport and in the color chooser, select a color with the exact same RGB value ( 0.2 at each)
back to the UV/Image Editor, change View to Paint and give a brush stroke.
The color of the brush stroke that is using the 0.2 values is of a completely different color than the image color that is using the same exact 0.2 RGB values.
With HSV value instead of RGB, the result is the same, both texture paint mode version of the color and the image editor color are completely different.
I thentested with entering HEX values for the colors (by example use 333333 for the brush and for the image).
The result is that the brush is using then the same color as the image set with the same HEX value, as it should.%%%
%%%forgot to mention, this is for 2.65a and even recent SVN from buildbot, this inconsistency was in 2.62 too.
But in 2.49b both RGB and HSV delivered the expected result, it worked good.%%%
%%%Note that with color management the values are managed too. This might not be always very clear though.%%%
%%%This is it, after reading your comment of the color management, i went to the scene panel and set the "Display Device" from the default "sRGB" to "None"
Then setting R : 0.2 , G : 0.2 and B : 0.2 in the image editor color gave me the same exact color as if i setup R : 0.2 , G : 0.2 and B : 0.2 in the Texture paint mode color.
So it looks like the color management is influencing RGB values in the Image Editor but is not influencing RGB values for the brushes in the Texture paint mode. If it is intended it is indeed very confusing for the user to see colors not being the same in every modes despite using the same RGB values.%%%
%%%Well, i hope i understand the issue correct and fix is correct in svn rev54293. Please test behavior here further and let me know if something is still wrong. For until then considering issue solved :)%%%
%%%Hello,
I just tested on r54347 from the buildbot and i can confirm the issue is fixed , RGB values now correspond to the same color in both UV/Image Editor and in the Texture Paint brushes.
Thank you.%%%
