Snap to face projection - Entire mesh is affected by projection when Proportional Editing mode is active, regardless of influence radius #34244
Reference: blender/blender#34244
%%%Windows 7, Nvidia GeForce GTX 560 Ti
Bug is present in 2.66 RC and 2.65.
Last working official version was 2.64.
Current buggy behaviour:
In editmode, when using snap to face, with projection and Proportional Editing mode (PE) active, the projection is done on the entire mesh, regardless of PE radius.
Expected behaviour (2.64):
When using projection and PE together, projection should only be applied to vertices inside the PE radius. Vertices outside the radius should be ignored.
Steps to repeat the problem in the attached file:
This makes it very cumbersome to use PE when doing retopology work. Especially annoying when using it on a mesh that completely wraps around another, as it will cause vertices on the back side to be projected to the front.
It used to be a big time saver, but was broken sometime after 2.64. Does not work in 2.65 or 2.66.
%%%I've seen some another trouble with the face projection snapping:
When the vert's you're going to project are in the same mesh there is a trouble:
(snap_to_faces_01.blend)
By all technical logic it's expected just to be projected on the underlying face(s) of this mesh.
I'm not sure that was by the design. And without "snap to other objects" checked it works like this. BUT in a workflow it's often necessary to show other objects while doing face snapping operations WITHOUT snapping to other objects (so I mean I must leave it unchecked). I didn't thought out this thing because that was a case of my modelling work.
I've just decided to "forget" about this and to delay before an emergence of some report close to my problem (b'coz it's not too crucial). I mean it's like a "combo" :) Two issues of one area.
And another issue that in some cases (when a surface to be projected on is not parallel to the view)... not simple cases... the projecting occurs wrong.. with some shift. I remember it's a side shift. Sorry, I can't recall that it was better before some version but I remember that it WAS better.. maybe in 2.5. I'm not sure. If you're going to touch this theme then I'll dig into this problem and I'll find a concrete case when I've got this issue.%%%
%%%Checking on a fix%%%
%%%fixed r54675.
@Moolah. You are raising 2 unrelated issues in this report (Nothing to do with snapping failing in proportional edit-mode).
The first point you make is intended behavior from what I can tell, even if you think its not ideal.
The second issue you don't give enough explanation for a developer to redo.
If you are sure these are bugs, please open separate reports.
closing.%%%
%%%@Campbell. Thank you! I got. I'll make the reports when I'll be closer to this issue.%%%
