inaccurate key config output #34366
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
2 Participants
Reference: blender/blender-addons#34366
vista 32bit
blender-2.66-windows32.zip
i have a custom key config set with the following settings(see image for better explanation)
3D view>Mesh>new
mesh.select_mode
Extend:false
Expand:true
Type:faces
Action:toggle
but when calling it with the hotkey, this is what i get:
bpy.ops.mesh.select_mode(use_extend=True, use_expand=True, type='FACE', action='TOGGLE')
Extend gets the value "true", and not false as it should(?)
1.open attached file
2.add a custom keymap in user pref >input>3d view> Mesh >add New
3.use same setting as attached file
4.Make sure you in vertex edit mode for the plane.And have atleast 1 vertex selected
5.press ctrl-shift+(+key)
6. Compare the output given in the "info" panel with settings set for the hotkey.
%%%Fixed in svn now, still not ideal but it's a bit of a limitation of our event / UI system. They were hardcoded to use shift/ctrl modifiers to set these options, now you can override them from the key configuration, but note you need to click the use extend option once to make that register.%%%
