Make Local on linked mesh object: object gets removed if redo function is used #34446
7 Participants
Reference: blender/blender#34446
%%%--- Blender version with error, and version that worked ---
2.66-official
If one changes the type for Make Local operator in Redo panel, object disappears (from scene as well as from bpy.data.objects)
Redo should either be disabled for this op, or made working.%%%
#44858 was marked as duplicate of this issue
#40428 was marked as duplicate of this issue
%%%Will investigate it.%%%
%%%I later notices these messages in system console (no report popup showed however):
Object Cube.001 lost data.
Warning: Warning in console
Warning: LIB ERROR: object lost from scene: 'Scene'%%%
Added subscriber: @mutantbob
◀ Merged tasks: #40428.
Added subscriber: @bliblubli
Added subscriber: @mont29
Old bug and nobody assigned to it :/ Maybe @mont29 can give it a go?
Added subscribers: @carlosdp, @MarioSottile
Added subscribers: @Sergey, @ideasman42
pfffff… this is a very nice can of worms. :(
So, as found by @carlosdp in D1376, the issue is that we do not re-read lib data blocks and ID placholders (ID_ID bheads) in undo context (in
blo_read_file_internal
), becauseBLO_read_from_memfile
copies lib datablocks and Main data directly from oldmain. The idea being, linked data do not change from undo/redo.This is valid as long as linked data was not changed by the undo step - but if some was deleted, it will be missing from oldmain, leading to data loss (note that does not only concerns objects, all linkable data types can be affected).
Now, we do can address that issue, by carefully mixing reuse of needed data from oldmain, and "normal" re-reading of missing one, see D1485. We already swim in some rather dark waters here imho, this gives a rather non-easy-to-follow code, but it seems to work quite well from some quick tests.
Nasty thing now: this leads us to another issue - re-reading some data from libraries means its address won't be the same as previously. Henceforth, any further redo will lose the data again, because it will try to find it (in fd->libmap) based on its old address.
I guess we could store someway in new ID that old address, but have the feeling that would be swimming in pitch black waters. So I’d end up voting for @carlosdp solution - revert that “smart” trick in undos - that, or accept the bug. Unless someone has a better idea? @ideasman42, @Sergey?
Hehe, actually, some pause was useful here - fixing the last point was simply a matter of adding old->new ID address to fd->libmap…
So, patch in D1485 seems to work OK - from quick tests. Would be nice if some user with complex lib-using file could stress-test it a bit…
This issue was referenced by
07332dd2bb
