changes to Influences in the texture panel don't update correctly. #34759
Closed
opened 2013-03-24 21:50:57 +01:00 by Glenn Melenhorst · 5 comments
windows7
- Blender version with error, and version that worked ---
2.66a
- Short description of error ---
When setting up textures to drive hair in cycles, the texture tab does not update the influence settings correctly
- Steps for others to reproduce the error (preferably based on attached .blend file) ---
1/ Open the blend I posted.
2/ go to the texture tab.
3/select ParticleSystem - Circle note what influences are set.
4/Select ParticleSystem_Cross. It has length set. now change the influences to something random.
5/reselect ParticleSystem_Circle and its influences stay the same as ParticleSystem_Cross.
The influences don't update as you change them.
%%%--- Operating System, Graphics card --- windows7 - Blender version with error, and version that worked --- 2.66a - Short description of error --- When setting up textures to drive hair in cycles, the texture tab does not update the influence settings correctly - Steps for others to reproduce the error (preferably based on attached .blend file) --- 1/ Open the blend I posted. 2/ go to the texture tab. 3/select ParticleSystem - Circle note what influences are set. 4/Select ParticleSystem_Cross. It has length set. now change the influences to something random. 5/reselect ParticleSystem_Circle and its influences stay the same as ParticleSystem_Cross. The influences don't update as you change them. %%%
Member
%%%Brecht: if render engine is set to "Internal", the particles update to show the active texture. For cycles not.
It also doesn't render it in Cycles, unless you switch back to internal and back to cycles.
Glenn: hey good to see you here! How's Blender life at Iloura?%%%
%%%Brecht: if render engine is set to "Internal", the particles update to show the active texture. For cycles not. It also doesn't render it in Cycles, unless you switch back to internal and back to cycles. Glenn: hey good to see you here! How's Blender life at Iloura?%%%
%%%Good Ton,
I just love showing our lighting department GPU Cycles, particularly as all those Autodesk sneak peek videos for 2014 are so underwhelming :)
Keep up the amazing work, all of you!
Glenn%%%
%%%Good Ton, I just love showing our lighting department GPU Cycles, particularly as all those Autodesk sneak peek videos for 2014 are so underwhelming :) Keep up the amazing work, all of you! Glenn%%%
%%%Fix in svn, thanks for the report.%%%
Reference: blender/blender#34759
