Rendering with OSL seems to cap "weird" numbers in certain places in the nodes #35591
Reference: blender/blender#35591
WinXP 32bits
Nvidia GeForce 250 GTS
From what i can remember, ever since OSL was avaiable it had this issue.
If you manually (or simply feeding from another node) input values outside the range you can get just by dragging on the sliders, on certain things like RGB values and as the mixing factor, with plain Cycles you can get some interesting effects, but if you enable OSL rendering those "unusual" values seem to get capped to the 0.0...1.0 range.
Render with OSL disabled, then render with OSL enabled and compare the results (the two smaller cubes have materials with manually entered values for a couple of things).
ps: clearly this scene is not a masterpiece, just somthing i threw together to show some of the differences%%%
%%%I can't see any issues with RGB nodes, if I add a color RGB node with values -5, 5, 5, it renders the same in OSL and SVM.
The issue is in the mix shader. /negative values).
Anyway, we should not "unlock" this in OSL, but clamp the Mix factor in SVM. %%%
%%%Brecht, I propose the following fix for SVM:
Index: D:/blender_dev/code/trunk/intern/cycles/kernel/svm/svm_closure.h
+++ D:/blender_dev/code/trunk/intern/cycles/kernel/svm/svm_closure.h (working copy)
@@ -599,6 +599,8 @@
decode_node_uchar4(node.y, &weight_offset, &in_weight_offset, &weight1_offset, &weight2_offset);
weight = clamp(weight, 0.0f, 1.0f);
float in_weight = (stack_valid(in_weight_offset))? stack_load_float(stack, in_weight_offset): 1.0f;
if(stack_valid(weight1_offset))
%%%That fix looks ok, please commit.%%%
%%%Is it really need to clamp the Mix factor?
I thought that the ability to use negative values with Mix shader - this is a feature, not a bug.
Not sure if I ever need this, but I can subtract shaders with negative Mix factor, e.g.
http://i.imgur.com/NNWVf6t.png%%%
%%%Mix closures outside of the 0-1 ranges are not really predictable, and can cause strange artefacts, better to limit this, instead of have nasty surprises, when entering a strange value by accident.
%%%Isn't out of range values used for fake caustics (by making the transparent shader actually emit more light than if it was 100% transparent in some parts, to emulate focusing the light) ?%%%
%%%Indeed. I forgot about fake caustics. Now it will be impossible with clamped Mix factor.%%%
%%%Although, no. I was wrong. This is not that cheat for fake caustic, about which I thought.%%%
%%%The color inputs to shader nodes are unclamped, and can be used with the add/mix shader for negative or > 1 values.%%%
