unselected node drag fails #35809
5 Participants
Reference: blender/blender#35809
%%%Hi guys,
Ubuntu 64, 16gb ram, 2* nvidia gtx560tioc
all official releases work, current trunk not (just compiled myself a clean one and tried a buildbot build)
When I try to drag a node in the cycles material nodes that is currently not selected, I can not catch it.
Just add a node material to the default cube and try to select and drag a currently unselected node. Most of the time, I can't drag it - my node rests in place while my mouse is moving further...just like I didn't press the left or right mouse button ..
Greetings, Thomas%%%
%%%Confirmed, Win 7 x64, Geforce 540M, current SVN.
To reproduce:
Left click on an unselect node, keep mouse pressed, then move. Node position does not change.
Works fine with 2.67b. It seems that if you select and not move immediately, the node is stuck. %%%
%%%@Ton, this error is caused by your commit r53218.
included patch to fix.%%%
%%%The error is related to the animated panels in the Nkey region. Same error is in 3d window too btw.
If you click-drag before animation ends things are OK though. So, normal faster click-drags work fine.
Issue has something to do with the timers - these are doing panel animation.
I wouldn't revert the fix I did, that was to enable panel animation in regions :) Real fix is elsewhere.%%%
%%%The problem was EVENT_NONE interfering with gesture, fix in svn now.%%%
%%%Hi Brecht, thanks for fixing it, just tried - works great!%%%
