Image Texture material node in Cycles handles semitransparency incorrectly #35812
2 Participants
Reference: blender/blender#35812
Windows 7 64-bit Service Pack 1, Mobile Intel 4 Series Express Chipset
Error:
Blender r57620 64-bit (http://builder.blender.org/download/blender-2.67-r57620-win64.zip)
Blender 2.67b 64-bit (official binary)
Working:
None I know of
The Image Texture material node in Cycles seems to handle semitransparency incorrectly.
In particular, if the image file contains semitransparent white pixels (R=G=B=1 and 0<A<1 in straight alpha), they become either semitransparent gray (R=G=B<A in premultiplied alpha) or semitransparent whiter-than-white (R=G=B>A in premultiplied alpha), depending on whether the “Open Shading Language” checkbox in the Render tab of the Properties window is checked or not.
Actual behavior:
In both step 2 and step 3, the plane is rendered as gradation. In step 2, the gradation is from white on the left to black on the right. In step 3, the gradation is from black to gray to black.
Expected behavior:
In both step 2 and step 3, the plane should be rendered as black, because all pixels in gradation.png are semitransparent white.
Notes:
%%%If you use both the color and alpha output of an Image Texture node, it will output unpremultiplied/straight RGB channels. So then it is valid to for RA. The reason it works that way is because it's more convenient for the typical mix shader node setup, if you plug alpha in the mix shader socket to blend, it already multiplies with the alpha, and you don't want that to happen twice.
http://wiki.blender.org/index.php/Doc:2.6/Manual/Render/Cycles/Nodes/Textures#Image_Texture
There was an issue with the OSL version not working as intended, fixed that now.%%%
%%%Oops, I did not know the Color output of the Image Texture node depended on whether the Alpha output was used or not. Thank you for the pointer. (I think that is very confusing, but it is a separate issue.)%%%
