Linking in a group with hair particles and force field doesn't affect the hair particles. #36300
2 Participants
Reference: blender/blender#36300
OS: Windows 8
Graphics card: Inter HD Graphics 4000
Blender version used: 2.68.0 revision 58386 and 2.68.1 revision 58611 (from builder.blender.org)
Blender version it worked on: none
Linking a group with hair particles and force field doesn't affect the linked object which contains the particle system.
However, appending that group affects the particle system.
I have this current directory hierarchy as follows:
/props contains the 'carpet.blend' file which has a plane with hair particles on it (both in a group called 'carpet'), affected by a single Force Field.
/scene contains the 'scene.blend' file where the 'carpet' group from 'carpet.blend' will be linked/appended into.
When doing a 'link' of the carpet group into the scene file, the hair particles doesn't seem to be affected by the force at all, given the force field is part of the linked group.
However, doing an 'append' of the carpet group into the scene file, the hair particles are affected by the force field. But already is a local group within the scene file and not a referenced/linked group.
Often, it is best to 'link' Groups/Objects for better organization, UI response, and doing appending often defeats this purpose.
%%%This is sort-of a duplicate of #35264 (the cause is the same): Force fields do not work in group instances. When linking the group with carpet mesh/particles + force field it also loads the individual objects of the group (they are in bpy.data), but they don't get linked into the scene themselves (linking is an ambiguous term here, the first usage meaning a copy of the data from another file, the latter meaning a "object base" in the scene that actually places an object in that scene).
Linking (not necessarily appending) the "Field" object explicitly into the scene file solves the issue, although it's not an optimal solution. It may be possible to solve the problem in a general way by allowing force field in group instances, but i cannot promise anything yet. Will have to see if it can be done cleanly without major hacks.%%%
%%%Thanks so much, Lukas.
%%%Closing this as a ToDo
http://wiki.blender.org/index.php/Dev:2.5/Source/Development/Todo/Tools#Collisions
It not really possible to fix with the way effectors (force fields and colliders) are used atm. Duplis are also primarily a visual feature, although i agree it would be helpful to support this at least in group instances.%%%
