in python inputs/outputs of created node group not accessable by their names #36584
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
2 Participants
Reference: blender/blender-addons#36584
Windows 7 64bit,
current (or all) versions with issue
when i create a 'ShaderNodeGroup' (+'NodeGroupOutput'+'NodeGroupInput') via script, i can not access its outputs and inputs by its names, even their names are unique, and visible when i iterate them by script.
i alwasy have to use the indices to get them.
node.inputs['blablabla'] -> fails
node.inputs- [x] -> works
(even when node.inputs- [x].name -> 'blablabla', or node.inputs- [x].identifier is set)
accessing by index
1.1. open the attached blend file
1.2. run script
1.3. it works
accessing by name (.outputs[key] or .outputs.get(key))
2.1. open the attached blend file
2.2. uncomment the test_case item 'BY_KEY' or 'BY_GET'
2.3. run script
2.4. it fails
%%%Your reported issue has been fixed in SVN. Thanks for taking the
time to report!.%%%
%%%thank you for the fix. :)%%%
