Lens Node does not work with other node inputs #36585
2 Participants
Reference: blender/blender#36585
blender-2.68-r59254-win64 gtx titan i7
Lens node only works with values and fails with inputs from other nodes.
Check the attached file. Press F12 and look at the compositor.
The Lens node has no effect even though the input map (material index) is ok.
The input map is also ranged between 0 and 1.
Thank you%%%
%%%This is a design limitation/missing feature: The dispersion and distortion inputs actually only allow single, constant value inputs. If they are connected to other nodes they will get evaluated once at the beginning, which only works reliably with nodes that calculate constants in turn (so you could use some math nodes for instance) but any kind of image-based input (such as the ID mask node) won't work here ...
It's a fairly common issue that should be handled and communicated on the node level, but needs some new node editor/compositor features. I've added it as a Todo item:
http://wiki.blender.org/index.php/Dev:2.5/Source/Development/Todo/Tools#Compositing%%%
