make link modifier error(soft body) #36994
Closed
opened 2013-10-08 03:24:30 +02:00 by joe stallman · 7 comments
Windows 7
- Blender version with error, and version that worked ---
Have tested with the following:
2.68a
2.63a
2.65
2.69rc1
- Short description of error ---
When we execute "make link" to an object with modifier "soft body". Nothing happens. what has to happen is that the rest of the chosen objects copies the same modifier of the active object with its configuration
- Steps for others to reproduce the error (preferably based on attached .blend file) ---
  1. Blender begins and it duplicates the cube
  2. To a cube to set "soft body"
  3. To select two cubes but the one that it has "soft body" to set like main selection (active object)
  4. To pulsate "Ctrl + L" and in "make links: modifiers"
%%%--- Operating System, Graphics card --- Windows 7 - Blender version with error, and version that worked --- Have tested with the following: 2.68a 2.63a 2.65 2.69rc1 - Short description of error --- When we execute "make link" to an object with modifier "soft body". Nothing happens. what has to happen is that the rest of the chosen objects copies the same modifier of the active object with its configuration - Steps for others to reproduce the error (preferably based on attached .blend file) --- 1. Blender begins and it duplicates the cube 2. To a cube to set "soft body" 3. To select two cubes but the one that it has "soft body" to set like main selection (active object) 4. To pulsate "Ctrl + L" and in "make links: modifiers" %%%
Author
%%%Campbell, seems to be a code from you in BKE_object_link_modifiers which explicitly skips adding modifiers for soft body and particle systems. But the thing is, BKE_object_copy_softbody does not create modifier which means no softbody would be applied on the destination object.
Same goes to BKE_object_copy_particlesystems it seems.
So my guess is that we need to check whether there're eModifierType_Softbody/eModifierType_ParticleInstance and if not add them?%%%
%%%Campbell, seems to be a code from you in BKE_object_link_modifiers which explicitly skips adding modifiers for soft body and particle systems. But the thing is, BKE_object_copy_softbody does not create modifier which means no softbody would be applied on the destination object. Same goes to BKE_object_copy_particlesystems it seems. So my guess is that we need to check whether there're eModifierType_Softbody/eModifierType_ParticleInstance and if not add them?%%%
@ideasman42, poke? :)
Member
Member
@ideasman42, poke++?
This issue was referenced by 9454377c71
This issue was referenced by 9454377c71f48ab5f10b523e002041c31324fbae
5 Participants
Reference: blender/blender#36994
