keyframing custom properties issue #37103
Reference: blender/blender#37103
cpu: intel core i3 2350 2.3 ghz
ram: 4 gb
gfx: intel hd graphics 3000
os: windows 7 home premium sp 1
error found in: 2.69 r60695
was working in: ?
key framing custom property sliders results in a stepped (integer?) curve and not a smooth (float?) bezier in the graph editor.
[apparently happens with all blend files]
i'm trying to use custom properties in the 3d view's property panel, to blend different actions in the nla editor via the action's influence sliders.
if you look at the attached screen capture, your'll see the graph editor curves are meant to be smooth bezier curves (when set to bezier interpolation) but currently they are stepped, resulting in the animation blending stuttering horribly when played back.
if this is not a bug per se, could you guys please at least give us the option when editing custom properties to switch between integer and float outputs?
%%%this is looking more like a bug in my opinion.
if i load up a default scene and create a custom property on the cube (without editing the custom property) then it does output a bezier. but if i edit the "prop" with a min of 1 and a max of 20, then replace the keyframes it converts it to integers, well it's curve is stepped and no longer a bezier, even though the graph editor still says the interpolation type is bezier.
i'm attaching the simple blend file i just tested this with.%%%
%%%i'm having trouble attaching the blend, trying again.%%%
%%%Note that interpolation type and "step" representation are two different things - you can have a Bezier interpolation with an integer property (and hence steped curve).
The only bug here is the "refreshing" of the displayed F-curve which is not correct when the type of the property changes…%%%
%%%thanks, and i understand the first part... but if i edit the custom property to values above 1, for example a min of 1 and max of 20, then it's not just the graph editor's visual representation of the stepped curve that is buggy, if this curve is going to be used as the input of a driver, then the drivers output is also integers, and if i edit the custom property again and change the values back to min of 0 and max of 1, then the resulting curve and driver output are still integers, which requires the custom property to be deleted and new one to be created, in order to get the bezier curve working again.
so can you fix this?%%%
Added subscriber: @JoshuaLeung
Proposal fix: D111
This issue was referenced by blender/blender-addons-contrib@51f5c994e9
51f5c994e9
Closed by commit
51f5c994e9
