Extension of mesh.bisect() by split to islands option #37254
6 Participants
Reference: blender/blender#37254
Purpose:
This patch extends the mesh.bisect() operator by a split option. With this option you are able to create 2 independent Mesh Islands out of the mesh parts in
front of and behind the bisection plane. Together with the fill option both open mesh island cutting loops will be filled with a face each. This way you can quickly
fracture a mesh manually into shards.
Usage: Simply use the bisect operator as usual, and check the split checkbox and optionally the fill checkbox to see the new functionality.
scorpion81
%%%Patch V2:
Reimplementation with edge_split and edgenet_fill operators, additionally using a material index and a smooth option for inner faces (accepted by edgenet_fill operator%%%
Added subscriber: @Sergey
Cambo, mind checking on this?
Added subscriber: @jta
It looks like this patch stalled so I am bumping it. Scorpion81, is this still needed or has a similar functionality been added somewhere else or with a different patch?
@scorpion81, did you look at updating this to use scanfill? it shouldnt be too much extra work to finish this off.
Added subscriber: @ideasman42
@ideasman42 , made a first attempt today, but i didnt manage it with triangle fill, unfortunately.
Triangle fill needs apparently the edges of the cut grouped by each face of the two sides of the cut.
Tried to wrap my head around on how best to separate those 2 edge sets.
But best result after filling one side of the mesh like before and splitting afterwards was a loose additional face, not being connected to the other piece of the cut.
So i ended up (for now) using fill_holes which can deal with the entire edge set, but i assume that isnt correct yet as well...
As the name says, holes will be filled there (instead of being retained) Will try further tomorrow and in the next time....
Or could you give me a hint on how to fix properly ?
bisect_split_v3.patch
argh, noticed unnecessary operator properties still being present in bisect operator (mat_nr, smooth) after posting it, so i have a fixed patch here
bisect_split_v3_fixed.patch
Ok, i managed to get some working triangle fill solution as requested, but i really recommend to use patch v3_fixed...
as v4 here is very very shoddy imho.... but i couldnt get it better so far....
v3_fixed works like a charm for multiple bisects, while v4 really gets into trouble there.
bisect_split_v4.patch
Ok, i fixed the wrong selection problem of v4 here, but v3_fixed still is better than v5 as the latter cant fill any sequential cuts i make,
(not even in default cube)
There are always some faces missing.
bisect_split_v5.patch
Added subscriber: @mont29
Removed subscriber: @ideasman42
Added subscriber: @dfelinto
Hi, thanks for your patch.
We are undergoing a Tracker Curfew where we are automatically closing old patches.
If you think the patch is still relevant please update and re-submit it. For new features make sure there is a clear design from the user level perspective.
