Command line render gives seg fault 11 on OS X #37301
6 Participants
Reference: blender/blender#37301
%%%I've gave category: Rendering as I'm not sure where this bug should go. Possibly into OS X specific if it doesn't appear on other platforms.
OS X 10.9; Intel HD5000
2.69 - with error; 2.68a - working
Running Blender render using command line gives a crash (Segmentation fault: 11) when running 2.69. The same command works using 2.68a.
While on Mac OS X:
$ cd dir_with_attached.blend
$ /Applications/Blender/blender.app/Contents/MacOS/blender -b "test.01.blend" -F PNG -x 1 -f 1
%%%After more tests I'm pretty sure the problem is with Maya key scheme. When it's turn on and saved to user settings/startup file Blender will crash when starting render from command line.%%%
%%%I'm able to reproduce it in Linux. Here's the contents of blender.crash.txt
Blender 2.69 (sub 1), Revision: 60966
backtrace
/usr/lib/blender/blender() [0xbfa72d]
/lib/x86_64-linux-gnu/libc.so.6(+0x364a0) [0x7fb531ba04a0]
/usr/lib/blender/blender(WM_keymap_list_find+0x12) [0xc08a12]
/usr/lib/blender/blender(WM_modalkeymap_add+0x6c) [0xc0934c]
/usr/lib/blender/blender(KeyMaps_new_call+0x21) [0x1802bb1]
/usr/lib/blender/blender(RNA_function_call+0x12) [0x1715372]
/usr/lib/blender/blender() [0xf7cd9e]
/usr/lib/x86_64-linux-gnu/libpython3.3m.so.1.0(PyObject_Call+0x7e) [0x7fb5387e207e]
/usr/lib/x86_64-linux-gnu/libpython3.3m.so.1.0(PyEval_EvalFrameEx+0x5858) [0x7fb538724a58]
/usr/lib/x86_64-linux-gnu/libpython3.3m.so.1.0(PyEval_EvalCodeEx+0x85c) [0x7fb53871ef6c]
/usr/lib/x86_64-linux-gnu/libpython3.3m.so.1.0(PyEval_EvalCode+0x3b) [0x7fb53872799b]
/usr/lib/x86_64-linux-gnu/libpython3.3m.so.1.0(+0x1fd98a) [0x7fb53888598a]
/usr/lib/x86_64-linux-gnu/libpython3.3m.so.1.0(PyEval_EvalFrameEx+0x6ef9) [0x7fb5387260f9]
/usr/lib/x86_64-linux-gnu/libpython3.3m.so.1.0(PyEval_EvalFrameEx+0x767b) [0x7fb53872687b]
/usr/lib/x86_64-linux-gnu/libpython3.3m.so.1.0(PyEval_EvalFrameEx+0x7796) [0x7fb538726996]
/usr/lib/x86_64-linux-gnu/libpython3.3m.so.1.0(PyEval_EvalFrameEx+0x704c) [0x7fb53872624c]
/usr/lib/x86_64-linux-gnu/libpython3.3m.so.1.0(+0x971c9) [0x7fb53871f1c9]
/usr/lib/x86_64-linux-gnu/libpython3.3m.so.1.0(PyEval_EvalFrameEx+0x421d) [0x7fb53872341d]
/usr/lib/x86_64-linux-gnu/libpython3.3m.so.1.0(+0x970b6) [0x7fb53871f0b6]
/usr/lib/x86_64-linux-gnu/libpython3.3m.so.1.0(_PyObject_CallMethodObjIdArgs+0xcd) [0x7fb538775a8d]
/usr/lib/x86_64-linux-gnu/libpython3.3m.so.1.0(PyImport_ImportModuleLevelObject+0x7f4) [0x7fb53875b904]
/usr/lib/x86_64-linux-gnu/libpython3.3m.so.1.0(PyImport_ImportModuleLevel+0x4c) [0x7fb53875be2c]
/usr/lib/blender/blender() [0xf83532]
/usr/lib/blender/blender(BPy_init_modules+0x272) [0xf83802]
/usr/lib/blender/blender(BPY_python_start+0xf8) [0xf743d8]
/usr/lib/blender/blender(WM_init+0xe4) [0xc06f34]
/usr/lib/blender/blender(main+0xc27) [0xbc4947]
/lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xed) [0x7fb531b8b76d]
/usr/lib/blender/blender() [0xbf9299]
%%%Could not reproduce the crash here. Does it happen if you add --factory-startup before -b ?%%%
%%%As I noted in a comment crash happens when Maya key scheme is selected and saved in preferences.
Crash does not happen after adding --factory-startup.%%%
%%%Cannot reproduce on OSX 10.9 with Blender 2.69.
just renders me the cube with transparent background, saves it as .png and exits without error.
Jens%%%
%%%For me 2.69 on OS X Mavericks does not segfault with or without "Maya key scheme is selected and saved in preferences"
same command as Jens same result.
This issue was referenced by blender/blender-addons-contrib@106699ecd7
106699ecd7
Closed by commit
106699ecd7
.The issue is now solved, thanks for the report!
Great! Glad I could help and thanks for your development. :)
