Knife tool not working properly #37510
Reference: blender/blender#37510
Operating System:
Ubuntu Release 12.04 (precise) 64-bit
Kernel Linux 3.2.0-49-generic
GNOME 3.4.2
Blender Version: 2.69.2
Knife Tool Bug:
When using the Shift+K function and cut trough the whole object it doesn't cut trough some of the small faces (small compared to the rest of the object and the viewport) and it is not a problem with the object, it has been tested on other objects on different scenes and computers. I am applying a set of screenshot for beter explenation:
Thank you for your time :) !
Added subscriber: @kirompower
kirompower, please reply and attach the .blend file that has the object in question, or any object that exhibits the bug. It is hard for me to reproduce such bugs without a .blend file.
Here yoy go :) One object duplicated twice, one is the original and the other one is when it is already cuted ( I have deleted the faces below the cut line for better illustration of the bug )
1.blend
And if you want to make a object yourself here is a quick example: make a cube 1x1 meters, then Ctrl+A and S so it is in scale, then in edit mode apply bevel with offset of 0.0015 (1.5mm) and 3 segments and thats it, if you try and cut the whole cube with shift+K all the way trough it will leave some of the small "beveled" faces uncut.
Thank you :)
Are you sure there are faces there? After doing the cut, I deleted all the faces below the cut. I couldn't see any left that hadn't been cut. There are some edges left, but those don't seem to be attached to faces.
Yep, there are faces, i think it is visible in the blend file I previously uploaded, but here are some screenshots to make sure
I tested the same problem on the test build (2.7 from the link: http://download.blender.org/release/Blender2.70/) and it is still present, I have attached a video showcasing the problem.
Screencast_2014-02-24_16:50:37.mp4
Operating System:
GNOME 3.4.2
I looked at this a bit, and think that the problem is that the distances involved are tiny, and we start to run into difficulties because of single-precision floating point tolerances. I don't know if I can find an easy fix.
I don't know if this might help, but I am curently running v2.68 and it works fine.
Also I noticed that the problem seems to be relative to the object, I mean if I my cube is 10 times bigger and then I do the bevel again 10 times bigger, the knife tool still won't cut trough the small faces, despite they are now 10 times bigger but still relatively small to the cube (for example my original cube is 2x2 meters and the bevel was 1.5mm, if I make a cube 20x20meters and do a bevel of 1.5 cm the problem is still there)
Is there any way I can increase that precision ?
This issue was referenced by blender/blender-addons-contrib@c1be7e12ee
c1be7e12ee
Closed by commit
c1be7e12ee
.I found my problem and fixed it with
c1be7e12ee
