Mask modifier + Metaball instancing producing wrong stats in top bar #37750
Reference: blender/blender#37750
Win7 x64, GTX 480
Broken: All versions
Worked: Never
If you use a Mask modifier to filter out vertices while doing Metaball instancing on the mesh then the stats in the top bar appear to be calculated for instancing without Mask modifier leading to wrong numbers. There are much greater numbers shown than being rendered or shown in viewport.
A .blend file is attached with a small point cloud from which the majority of points is randomly filtered out by a Mask modifier for the rest to be used for Metaball instancing. Try to apply the modifier to see the difference.
On larger point clouds this can ultimately lead to integer overflow showing even negative numbers.
Note that you better don't try to show the whole point cloud without disabling the Metaball layer first, otherwise Blender will most likely hang.
metaball-stats.blend
Added subscriber: @KaiKostack-3
This issue was referenced by blender/blender-addons-contrib@8b53717c78
8b53717c78
Closed by commit
8b53717c78
