Inconsistency - Remove Selected From Active Group #37769
Reference: blender/blender#37769
Possible inconstancy between:
3D View Editor Header > Object > Group > Add Selected To Active Group
(SHIFT+CTRL+G)
3D View Editor Header > Object > Group > Remove Selected From Active Group
(SHIFT+ALT+G)
Reason: They are named as if they are the inverse of each other. But they don't
work in a similar way.
Attached Blend file: group.blend1
Example
Cube A is member of 1 Group, while Cube B is a member of groups 2 and 3.
If I select Cube A and then shift select Cube B and then activate
Add Selected To Active Group. Blender will then scan Cube B (active object)
and present me with a list of groups it is a member of. Allowing me to
select a group I want to add to the other selected objects.
However if I select Cube A then shift select Cube B and use the
Remove Selected From Active Group operator, things work differently.
What it does is scan the active object for all the groups it belongs
to and then removes all those groups from all the other selected objects and
itself. No menu is displayed offering to remove a specific group that the active
object has from the other selected objects.
It would be useful if this command worked in a consistent way to the
Add Selected To Active Group but for removal of groups.
If that not possible maybe it would be a good idea to rename
Remove Selected From Active Group to Remove Selected From Active Groups
making it plural gives a clue that all the groups of the active object
will be removed from the selected objects.
Added subscriber: @TerryWallwork-1
Added subscriber: @dro76wal
This issue was referenced by blender/blender-addons-contrib@653d645587
653d645587
Fixed now, thanks for the report.
Closed by commit
653d645587
