Cycles / CUDA detection fails when Blenders path contains umlauts. #37817
5 Participants
Reference: blender/blender#37817
Windows 7 x64, Geforce 540M
Broken: Blender 2.69.7
CUDA does not show up in the User Preferences, if Blender is located in a directory with umlauts. (like D:\blender_dev\install\blenderöä)
I am not sure where the exact error is, but it might be inside OIIO: this_program_path() uses GetModuleFileName() to retreive the path, I guess GetModuleFileNameW() should be used here.
I tried to hack something together and recompiled the OIIO lib, but the error in Cycles remained. So either my code is wrong or the problem is somewhere else.
#include "dassert.h"
#include "sysutil.h"
#elif defined(_WIN32)
#elif defined(FreeBSD) || defined(FreeBSD_kernel)
Added subscriber: @brecht
is not used when Cycles runs from inside Blender. For standalone this fix seems like it would be needed though.I suspect
cuModuleLoad
is the problem, I couldn't figure out from the documentation what kind of encoding it expects. Probably utf16 on Windows, but I made a quick patch to usecuModuleLoadData
instead which should solve the problem: cycles_utf16_cuda_path.diffI didn't test this, don't have a Blender build on Windows at the moment.
I had to change 2 lines to be able to compile it in FILE *path_fopen()
The result still fails though.
Added subscriber: @Sergey
Is someone looking into this issue?
Didn't checked further since Brechts patch.
This issue was referenced by blender/blender-addons-contrib@241fccaf6a
241fccaf6a
Closed by commit
241fccaf6a
.Added subscriber: @late-4
This fix did not work. I played around bit, and came up with this and it does not crash anymore:
static boost::filesystem::path to_boost(const string& path)
ifdef _MSC_VER
else
endif
static string from_boost(const boost::filesystem::path& path)
ifdef _MSC_VER
else
endif
Changed status from 'Resolved' to: 'Open'
I don't think we can simply assign a utf8 string to an utf16 string like that, that won't work for non-ascii characters as far as I know.
Committed a tweak to my fix, which works for me anyway:
{d980c3eccbd020a9ff7137659e7cbfbc5adb125d}
OSL works again, thanks, also no further GPU crashers.
