Align to view rotation glitch #38217
Reference: blender/blender#38217
Windows 7 home premium 64bit,
Broken: (2.69.8, Hash:
e998465
) (Older versions as well)Short description of error
Moving objects through X,Y,Z (in side bar) make models face down. While (Align to view) is in use.
Add "Monkey" then click "Align To View" Check box. Then adjust the location ether X,Y,Z in the side bar. The model will then face downward, for some reason. Unchecking and rechecking the box will fix it but to the current view of course, which could of changed at any point.
Added subscriber: @LewisVeasey
Added subscriber: @sreich
"Align To View" is being disabled when roration (and for some reason any of the other properties) is changed.
Seems to me this is not actually needed, so we could just do this: axis_align_fix.diff
Would be good to grey out the rotation property when "Align To View" is enabled then.
Thank you! Do you think you could change the check box to a button instead? It almost seems to be pointless to be a check box. On second thought, you could have it so the model follows the view in real time till you apply the model settings. As a Pose to checking the box and unchecking to update the model's rotation to view. If you could do one or the other, that would be greatly appreciated, it's just a thought, so don't feel obligated to do it.
@sreich - not sure this is right - rotation is supposed to override view alignment, also - any changes here should be matches in pythons add object utility function, will check on this,
>Align to view rotation glitch<to Align to view rotation glitchIf rotation is supposed to override view alignment, then having it as a checkbox is weird.
That means that you have to uncheck and check "Align To View" again to reactivate it after changing rotation.
That's exactly what I was thinking. I think a button would make more sense then a check box.
The reason its not a button (an operator which overwrites the current rotation values) is that this can be enabled by default in the preferences, so that would mean you couldnt run the opeator with this option enabled by default.
It could be made to work if the user preference would initialize rotation values when the preference was enabled.
but it does complicate things a little, since this means every operator would need its own draw function which adds in an operator button to perform this action.
... or we could have some automatic detection of this case so the template draw functioni knows to add a an operator button for the rotation values.
But this is a bit odd, another strange behavior is you can orbit the view, then re-enable align view to get a new rotation.
There is some logical conflict here, but the initial report states that:
"The model will then face downward, for some reason"
Which is in fact quite logical since you're editing the rotation values which have been set already by the viewport.
We could make some improvements here (wrt rotating the view then changing align option and making it more clear which is set...)
But this is more of a TODO then a bug.
There is still a bug here though.
As the report mentiones, not only rotation, but location (and in fact every other property change) will disable view alignment.
Ok, I see the bug now happens with Suzzane but not a Cube. checkign on it...
This issue was referenced by blender/blender-addons-contrib@38e683cbb1
38e683cbb1
Closed by commit
38e683cbb1
