Face snapping fails on Orthographic view #38358
5 Participants
Reference: blender/blender#38358
openSUSE 12.3 64bits
NVIDIA 480GTX SC
Broken: Blender 2.69.10
c0a4089
Face snapping in Blender fails constantly on Orthographic view. Basically it snaps to the back faces of the model.
This problem has always existed in the raytraced snapping. I never reported it because I thought it was unfortunate but normal since I always work in orthographic mode. However I just recently noticed how in perspective mode it works flawlessly!
Open Snap.blend
Slowly move X arrow to the right
Suddenly the vertex snaps to the back surface!
Added subscriber: @zanqdo
Added subscriber: @mont29
Added subscribers: @ideasman42, @brecht
Ok, so issue seems to be in ray/tri intersection code… I made some prints (the cursor is over face 3641, but very close to the boundary with face 3640, ~0.001BU away), r_loc is the intersection point found (i.e. the result):
Good result (i.e. intersection with face 3641 detected):
Next check (just a tad closer to boundary, but still over 3641): bad result (i.e. intersection with neither face 3641 nor 3640 detected):
As far as I can see, it’s another stupid precision issue, I’d say caused by the fact that the org point of ray in ortho view is rather far away (~ 940BU here), while in perspective it is much closer. This is due to
ED_view3d_win_to_segment()
(in view3d_project.c), which places org point at 1000 when in ortho view. Setting this value to e.g. 10.0f indeed fixes the issue.Not sure what we can/want to do here, perhaps switch to double, @brecht, @ideasman42, ideas?
Doubles would be enough to solve this problem I think, they need to propagate pretty far then though since snapping uses a BVH tree and all that code uses floats.
Another possibility would be to to return different values than ray start/end position from
. Inmadd_v3_v3v3fl(r_ray_start, vec, rv3d->viewinv- [x], 1000.0f);
it does small valuevec
+ large valuerv3d->viewinv- [x] * 1000.0f
, which causes the small value to be rounded away and precision lost.If you return a ray position (
vec
), ray direction (rv3d->viewinv- [x]
) and ray start/end distance (1000.0f
and-1000.0f
) and use those directly in the intersection function, then you would avoid the precision issue here.If you're lucky you can just modify
ED_view3d_win_to_ray
to use those values and it works, by getting a more accurate ray direction, but I'm not sure it's enough.If it's not enough, you end up with a similar issue as doubles though, in that you'll need to modify more code. You would need to carefully ensure the snapping/BVH code can handle a ray distance start/end range with the start distance negative, instead of just a single positive distance starting from 0.0 at the ray start.
Thanks for those hints, @brecht.
I can confirm having a better dir is not enough to fix the issue… I’ll have a look at modifying bvh & co to handle orco + offset, and also check knife code more in depth (Howard had a similar issue, which he fixed by bounding min/max to the object's limits… would avoid me the need to modify bvh & co). No small change in any case.
This issue was referenced by blender/blender-addons-contrib@77089a3bf2
77089a3bf2
Closed by commit
77089a3bf2
.@mont29 That's awesome, game changer for me! However my original test file Snap.blend stopped working for some reason! It wont snap. I can't reproduce in a new file tough.
Changed status from 'Resolved' to: 'Open'
This issue was referenced by blender/blender-addons-contrib@810c6d1880
810c6d1880
Closed by commit
810c6d1880
