VSE: Clips with Alpha Over against a transparent background fail to reflect opacity changes #38557
Closed
opened 2014-02-09 10:28:45 +01:00 by Seth L. · 7 comments
Observed on Mac OS X 10.6 and 10.8
Broken: 2.69.0 r60991 Also confirmed on latest unofficial build 2.69b53f310
Worked: never, as far as I know
In the Video Sequence Editor a clip with its blend mode set to Alpha Over cannot have its Opacity adjusted when over a transparent background. I observed this with PNG image sequences, but it may occur with other file types as well.
If a solid background image is added to a channel beneath the transparent clip the problem disappears.
This leads me to suspect that Alpha Over was coded only to account for transparency over solid - not transparency over tranparency.
This bug prevents image sequences with transparency from being composited correctly and in that regard is a workflow-stopper.
For example if a client wanted an animated logo fading in over a transparent background this bug would stop you from being able to produce it.
  1. Get a PNG with transparency. I am providing one below.
  2. In the Video Sequence Editor timeline choose Add > Image > and add the PNG.
  3. With the clip selected, under 'Edit Strip' change the Blend mode to 'Alpha Over'.
  4. Lower the clip's Opacity slider and see no effect at all. Even with the slider at 0 the clip will still be fully visible.
Refreshing the Sequencer doesn't help. Neither does reloading the .blend.
A PNG with transparency for testing:
An example .blend (uses above .png file)
vse-alpha-over-opacity-bug.blend
**System Information** Observed on Mac OS X 10.6 and 10.8 **Blender Version** Broken: 2.69.0 r60991 Also confirmed on latest unofficial build 2.69b53f310 Worked: never, as far as I know **Short description of error** In the Video Sequence Editor a clip with its blend mode set to Alpha Over cannot have its Opacity adjusted when over a transparent background. I observed this with PNG image sequences, but it may occur with other file types as well. If a *solid* background image is added to a channel beneath the transparent clip the problem disappears. This leads me to suspect that Alpha Over was coded only to account for transparency over solid - not transparency over tranparency. This bug prevents image sequences with transparency from being composited correctly and in that regard is a workflow-stopper. For example if a client wanted an animated logo fading in over a transparent background this bug would stop you from being able to produce it. **Exact steps for others to reproduce the error** 1. Get a PNG with transparency. I am providing one below. 2. In the Video Sequence Editor timeline choose Add > Image > and add the PNG. 3. With the clip selected, under 'Edit Strip' change the Blend mode to 'Alpha Over'. 4. Lower the clip's Opacity slider and see no effect at all. Even with the slider at 0 the clip will still be fully visible. Refreshing the Sequencer doesn't help. Neither does reloading the .blend. A PNG with transparency for testing: ![suz-with-alpha.png](https://archive.blender.org/developer/F76557/suz-with-alpha.png) An example .blend (uses above .png file) [vse-alpha-over-opacity-bug.blend](https://archive.blender.org/developer/F76559/vse-alpha-over-opacity-bug.blend)
Author
Author
Added subscriber: @quantumanomaly
Sergey Sharybin self-assigned this 2014-02-11 09:37:33 +01:00
This issue was referenced by blender/blender-addons-contrib@23fe23f951
This issue was referenced by blender/blender-addons-contrib@23fe23f951f017438dfd8e57eadc5c70d027417d
This issue was referenced by 23fe23f951
This issue was referenced by 23fe23f951f017438dfd8e57eadc5c70d027417d
Closed by commit 23fe23f951.
Author
Thank you for the prompt fix, sergey! You're awesome!
Reference: blender/blender#38557
