James Kinne #38753
Closed
opened 2014-02-22 05:48:09 +01:00 by James Kinne · 15 comments
Windows 7 Ultimate EVGA GTX 580
2.69.11
hash: 10f4c62
Using blender internal/blender render, every time I try to set the Physics/Cloth/Preset for a basic mesh plane to a certain type cloth I get an error pop up screen saying
"C:\User . . ... . . . . .2.69\scripts\startup\bl_operators", presets.py, line 210, in execute bpy.ops.script.python_file_run(filepath=filepath)
This build runs good my windows 8 machine. Don't know why . . . Every thing else seems to work good in Window 7 too though I'm sure I don't use everything else, however I do use quite a bit.
Windows 7 Ultimate EVGA GTX 580 **Blender Version** 2.69.11 hash: 10f4c62 Worked: (optional) **Short description of error** Using blender internal/blender render, every time I try to set the Physics/Cloth/Preset for a basic mesh plane to a certain type cloth I get an error pop up screen saying "C:\User . . ... . . . . .2.69\scripts\startup\bl_operators", presets.py, line 210, in execute bpy.ops.script.python_file_run(filepath=filepath) This build runs good my windows 8 machine. Don't know why . . . Every thing else seems to work good in Window 7 too though I'm sure I don't use everything else, however I do use quite a bit.
Author
Author
Added subscriber: @jkcinci
Author
blender 2.69.0 r20995 and all the builds I have from 2.59.0 r39654M on have the same problem, it may go back further than this, the 2.57 build works great on Windows 7 Ultimate.
Author
Here is a full copy of the error pop up screen from blender 2.69.0 r60995
File "C:\Users\J1\Desktop\Blender Zips & Exe's\blender-2.69-windows64 (1)\blender-2.69-windows64\2.69\scripts\startup\bl_operators\presets.py", line 210, in execute
File "C:\Users\J1\Desktop\Blender Zips & Exe's\blender-2.69-windows64 (1)\blender-2.69-windows64\2.69\scripts\modules\bpy\ops.py", line 188, in __call__
  ret = op_call(self.idname_py(), None, kw)
RuntimeError: Error: File "", line 1
  f=open(r'C:\Users\J1\Desktop\Blender Zips & Exe's\blender-2.69-windows64 (1)\blender-2.69-windows64\2.69\scripts\presets\cloth\cotton.py');exec(f.read());f.close()
SyntaxError: invalid syntax
location: C:\Users\J1\Desktop\Blender Zips & Exe's\blender-2.69-windows64 (1)\blender-2.69-windows64\2.69\scripts\modules\bpy\ops.py:188
Here is a full copy of the error pop up screen from blender 2.69.0 r60995 Traceback (most recent call last): ``` File "C:\Users\J1\Desktop\Blender Zips & Exe's\blender-2.69-windows64 (1)\blender-2.69-windows64\2.69\scripts\startup\bl_operators\presets.py", line 210, in execute bpy.ops.script.python_file_run(filepath=filepath) File "C:\Users\J1\Desktop\Blender Zips & Exe's\blender-2.69-windows64 (1)\blender-2.69-windows64\2.69\scripts\modules\bpy\ops.py", line 188, in __call__ ret = op_call(self.idname_py(), None, kw) ``` RuntimeError: Error: File "<string>", line 1 ``` f=open(r'C:\Users\J1\Desktop\Blender Zips & Exe's\blender-2.69-windows64 (1)\blender-2.69-windows64\2.69\scripts\presets\cloth\cotton.py');exec(f.read());f.close() ^ ``` SyntaxError: invalid syntax location: C:\Users\J1\Desktop\Blender Zips & Exe's\blender-2.69-windows64 (1)\blender-2.69-windows64\2.69\scripts\modules\bpy\ops.py:188 location: <unknown location>:-1
This issue was referenced by blender/blender-addons-contrib@99edd29835
This issue was referenced by blender/blender-addons-contrib@99edd29835fca6128ff05cc1e67885448eadc62d
This issue was referenced by 99edd29835
This issue was referenced by 99edd29835fca6128ff05cc1e67885448eadc62d
Closed by commit 99edd29835.
Changed status from 'Resolved' to: 'Open'
Added subscriber: @kjym3
I have prepared D383 to fix a problem introduced by the revision 99edd29.
The problem is that module local names of a script such as classes and functions are not accessible. Here is a simple Python script to demonstrate the issue.
test.py
The execution of this script by means of the '--python' command line option fails as follows:
> blender --background --python test.py
  File "<string>", line 1, in <module>
  File "<string>", line 8, in <module>
  File "<string>", line 5, in main
NameError: global name 'foo' is not defined
The task is reopened. Code review of D383 is duly acknowledged.
I have prepared [D383](https://archive.blender.org/developer/D383) to fix a problem introduced by the revision 99edd29. The problem is that module local names of a script such as classes and functions are not accessible. Here is a simple Python script to demonstrate the issue. [test.py](https://archive.blender.org/developer/F80021/test.py) The execution of this script by means of the '--python' command line option fails as follows: ``` > blender --background --python test.py : Traceback (most recent call last): File "<string>", line 1, in <module> File "<string>", line 8, in <module> File "<string>", line 5, in main NameError: global name 'foo' is not defined ``` The task is reopened. Code review of [D383](https://archive.blender.org/developer/D383) is duly acknowledged.
Tamito Kajiyama self-assigned this 2014-03-05 17:40:27 +01:00
Added subscriber: @ideasman42
Closed by commit a8dc5b2. Thanks @ideasman42 for the quick response.
Author
I believe that the intention of the
Constraint / Relationship / Follow Path
and the
Modifier / Deform / Curve
were not meant to be compatible.
The good new is I've found the solution to my application in the Graph Editor.
Your time and consideration are greatly appreciated.
I believe that the intention of the Constraint / Relationship / Follow Path and the Modifier / Deform / Curve were not meant to be compatible. The good new is I've found the solution to my application in the Graph Editor. Your time and consideration are greatly appreciated.
Reference: blender/blender#38753
