Blender Internal: Inverting alpha looks odd in material node setting. #38773
Reference: blender/blender#38773
Win7 64bit | FX2700M
Broken: 2.69.11
10f4c62
Worked: n/a
When trying to invert alpha output for material node, it works differently from what it does in Compositing mode.
Please see attached image and .blend file. Here, it seems that the Fac and Color input for the Invert node function sort of "inversely", or I can be wrong on this? Thanks for checking.
alpha_invert_mat.blend
Added subscriber: @ZhangYu
Added subscriber: @LukasTonne
This is a bad inconsistency in conversion of the "value" alpha type to the "color" input type of the invert node.
What should happen is that a value x is converted to a color (x,x,x) using this function:
https://developer.blender.org/diffusion/B/browse/master/source/blender/nodes/shader/node_shader_util.c;cb1b6b549e8cd8eb6cb40fa03818a913e1f45c00$55
Most nodes do this correctly by reading input stack values through this function, so they get the desired type no matter what the input is,
e.g.:
However, a lot of nodes don't actually use this function and simply access the input stack values as-is,
e.g.
This should be unified, so all nodes use the same conversion methods. However we need to be aware that this might break a lot of existing node setups that are based on the faulty behavior!
Also the opposite case of converting colors to single values is a bit questionable in the aforementioned function: From a color (r,g,b) you get a "grayscale" value of (r + g + b) / 3, while just using the r component might be more appropriate. This could happen for example in the math node, which also omits the conversion function:
https://developer.blender.org/diffusion/B/browse/master/source/blender/nodes/shader/nodes/node_shader_math.c;cb1b6b549e8cd8eb6cb40fa03818a913e1f45c00$53
Added subscriber: @brecht
@brecht: What's the best course of action here? Changing it could break existing nodes quite badly as well ...
Well this is pretty bad. I think if we are going to break compatibility then now for 2.70 is the right moment, so I think we should do it.
I think the average is the right behavior, there's no reason red should be more important than other channels.
This issue was referenced by blender/blender-addons-contrib@3ae641eb02
3ae641eb02
Closed by commit
3ae641eb02
