Custom Properties Edit popup clears bpy.types properties if value is set to different type (string / int / float / list) #38778
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
6 Participants
Reference: blender/blender-addons#38778
ID-Properties as well as bpy.types properties show up in the Custom Properties panel, although they are separated from Python perspective (they aren't internally).
If you add a bpy.types property...
it will show in the Custom Properties panel, and you can change it there (even to
123
or[1,2,3]
, it will be interpreted as string).But if you click the Edit button and type e.g.
123
into the popup's value field and confirm, the property (bpy.context.object.prop
) will be cleared and disappear from panel (there's no ID property with this name either).If the property is a bpy.types property, there shouldn't be type casting, and it would avoid losing this property.
There's another issue if you use
.prop
as property name:Try to add an ID property in the panel by clicking Add - it will try to create a property with the default name
prop
(+number if needed). But as there's a bpy.types property with that name, it seems to name-conflict and is removed immediately.I guess it should check for bpy.types properties and use a name not already in use?
Added subscriber: @CodeManX
Added subscriber: @soppera
Removed subscriber: @soppera
Added subscribers: @ideasman42, @Sergey
@ideasman42, think this one is for you?
Added subscriber: @SatishGoda
This issue was referenced by blender/blender-addons-contrib@bb62f9a582
This issue was referenced by blender/blender@bb62f9a582
Closed by commit blender/blender@bb62f9a582.
