Problem with particle age #38811
Reference: blender/blender#38811
http://www.pasteall.org/blend/26872
win7 64bit ATi 7850
Broken: (example: 2.69)
Wrong Particle Age with two Objects conatining a particle System
Particle age on system 1 jump back to 1 when particle system 2 emits a particle
Particle age on system 2 copy age of the particle on system 1
In the blend file you can see the problem on frame 15 (in render preview)
Text from stackexchange:
have a problem with my cycles Material Setup.
I have an ParticleSystem that use a object as dupli object. The Material of the Dupli Object depends on the age of the particle. Up to here it works fine.
If i add a second particle system (on another object) and use a dulpi object that also depends on particle age things become weired.
At the moment the first particle of the second particle system is emitted the particle copy the age of the first particle system and the the age of the first particle system gets back to 1.
In the attached file both particle system have only one particle and both
Added subscriber: @Andreas80
Added subscriber: @gandalf3
Added subscriber: @LukasTonne
Note: You can (and should) attach files directly to bug reports instead of using pasteall, just drag the file into the phabricator window.
The blend file is too big to upload it here. It was easier to share it on pasteall than scale the texture down. Sry my fault!
This issue was referenced by blender/blender-addons-contrib@0bef196894
0bef196894
Closed by commit
0bef196894
.Tested with blender-2.69-70924a7-win64 .
No Problems anymore. Thanks for the fix ;)
