Mark/Clear seam misbehaves when executed from spacebar search menu in 3D view #38819
5 Participants
Reference: blender/blender#38819
Windows 7 64bit, Nvidia GT 610
Broken: 2.70 RC
10f4c62
Worked: 2.63
Steps:
Added subscriber: @auuman_anubis
I spend a lot of time Unwrapping objects these days, if there was a static tic-box dedicated to "mark/un-mark" edges; it would be a great benefit to my workflow. I use the search menu as a way to sort-of "spawn" a button to mark edges, but this has become a little cumbersome with this bug lol
Thanks to whoever will look into this, much appreciated :)
Bug confirmed, looking at it.
By the way, are you familiar with the Ctrl+E menu?
This issue was referenced by blender/blender-addons-contrib@d47d030275
d47d030275
Closed by commit
d47d030275
.Fixed now, thanks for the report
This issue was referenced by blender/blender-addons-contrib@073a1f8f7c
073a1f8f7c
Added subscriber: @ideasman42
This isnt a bug, there are probably 100's of similar cases where an operators default behavior isnt exactly as you expect based on previous execution.
This is made a little more confusing when the some operator has an option to perform the opposite action (like a parent opeator with the uption to un-parent),.
even so, operators are configured to execute sensibly from the keymaps, toolbars and menus.
running operators from the search popup has mixed results.
An alternative could be never to re-use an operators last used settings whenever its executed from the search popup.
I see, I like the alternative that you presented Campbell, (operators never using last settings, whenever it's executed from the search) because this would give a constant result when the command is executed (instead of appearing 'random' if the user doesn't understand why the same command yield a different result).
I would rather just use the hotkey, but I need a hand free for my morning tea :)
It would help if the hotkeys were included in the tool tips, and next to the items in the search pop-up. (this is how I learned Photoshops hotkeys)
Perhaps the actions can be separated in the search pop-up.
Clear Seam being listed as a separate item from Mark Seam in search, allowing for constant results when either are selected?
@auuman_anubis,
Hotkeys are included in tooltips and the search popup.
the issues is internal functionality often doesn't make sense to split up into many operators, said differently, operators are not designed primarily to be accessed from the search popup.
How operators work is general design we can always improve on, but not a bug.
Not for mark, and clear seam. I'm looking at the list right now, no hot key included in the tooltip for seam marking.
back on the search pop up, I thought this was a bug because this was a new behavior that wasn't present in 2.63
I don't mean to push it one way or the other, I'm still learning and I appreciate all that's been done :)
Thank you for looking into this :)
The tooltip is for the menu (Ctrl+E),
While looking into this report I noticed some odd operators showing up in the search popup :)
Committed
497e1de25b
ece755ffe6
d2548f561c
Added subscriber: @ZsoltStefan
@ideasman42
"...operators are not designed primarily to be accessed from the search popup."
Then what is the search for? It's only functionality is direct access to the operators.
There is one 3D application I used to use, with a pretty cool search function. Searching for a tool/operator opened up the menu or toolbar where the tool was and highlighted the tool (actually used a sort of floating tooltip with a large arrow pointing at it), so users could learn where the tools/operators can be accessed. Otherwise they would keep on using the search.
