Boolean modifier - intersection fails for Suzanne and a cuboid #38962
Closed
opened 2014-03-05 02:07:21 +01:00 by CodeManX · 12 comments
Member
Windows 7
Broken: 2.69.11 ef40e889c
Cannot execute boolean operator appears at certain cuboid rotation angles, test file: intersect.blend
The following error is printed to console:
CSG failed, exception extern\carve\include\carve/csg_triangulator.hpp:396  tri_e
dge.find(e1) != tri_edge.end()
After a pretty aggressive remove doubles, it prints:
CSG failed, exception non intersecting group is not IN or OUT! (poly_b)
uncontained hole loop does not share vertices with any face loop!
CSG failed, exception non intersecting group is not IN or OUT! (poly_a)
CSG failed, exception extern\carve\lib\triangulator.cpp:916  "didn't manage to l
ink up hole!"
Is it a known limitation even with new CARVE integration? And what exactly makes it fail?
**System Information** Windows 7 **Blender Version** Broken: 2.69.11 ef40e889c **Short description of error** `Cannot execute boolean operator` appears at certain cuboid rotation angles, test file: [intersect.blend](https://archive.blender.org/developer/F79951/intersect.blend) The following error is printed to console: ``` CSG failed, exception extern\carve\include\carve/csg_triangulator.hpp:396 tri_e dge.find(e1) != tri_edge.end() ``` After a pretty aggressive remove doubles, it prints: ``` CSG failed, exception non intersecting group is not IN or OUT! (poly_b) uncontained hole loop does not share vertices with any face loop! uncontained hole loop does not share vertices with any face loop! CSG failed, exception non intersecting group is not IN or OUT! (poly_a) CSG failed, exception extern\carve\lib\triangulator.cpp:916 "didn't manage to l ink up hole!" ``` Is it a known limitation even with new CARVE integration? And what exactly makes it fail?
Author
Member
Author
Member
Added subscriber: @CodeManX
Added subscriber: @joel.godin
For me this bug works just by adding cube, add monkey, add boolean to monkey (leave default intersect) choose cube, crash.
Crash log attached.
BoolBug.txt
OSX 10.9.2
For me this bug works just by adding cube, add monkey, add boolean to monkey (leave default intersect) choose cube, crash. Crash log attached. [BoolBug.txt](https://archive.blender.org/developer/F79974/BoolBug.txt) OSX 10.9.2
Added subscriber: @ignatz
I'm not qualified to examine the code, but I do know that the Suzanne model is not a completely closed model. To be precise, the eyes are open areas stuck into the head and I believe this would cause problems for the boolean operation.
Just ran a test. I did the following with the file in question: (A) selected Suzanne, went into edit mode and removed floating eye pieces. (B) Then filled up Suzanne's open eye sockets, recalculated mesh and then the boolean operation worked as expected with no complaints.
Final thought: Would it not be a good idea at this late date to change/alter the default Suzanne model so that it IS a closed 3D shape?
This issue was referenced by blender/blender-addons-contrib@6ddb1faca9
This issue was referenced by blender/blender-addons-contrib@6ddb1faca976744c2c714c242d781cd42a226ef0
This issue was referenced by 6ddb1faca9
This issue was referenced by 6ddb1faca976744c2c714c242d781cd42a226ef0
Closed by commit 6ddb1faca9.
5 Participants
Reference: blender/blender#38962
