OSL Attribute node only works when SVM Attribute node is present #39415
2 Participants
Reference: blender/blender#39415
Linux Mint 15, 64-bit
GeForce GTX 650
CPU: AMD FX-8320
Broken: 2.70
765d077
The OSL attribute node only works when the SVM Attribute node is present in the graph AND connected to another node (excluding Input and Output nodes)
(Make sure to use CPU rendering, and Open Shading Language is checked on)
Using the default cube, add some Vertex Colors to it
blender/intern/cycles/kernel/shaders/osl_attribute.osl
For it to work, you'll need to do the following (after the above steps):
Add any node (could it be an Image Texture or a Math node, any node), but do not connect it to the others
Blendfile: getattribute.blend (Simply unplug the Attribute node, or change/erase the name in it)
Added subscriber: @kevindietrich
I just did a test and the same happens with the UV Map node (D230).
Added subscriber: @LukasTonne
This is a known limitation of OSL in cycles: The way attributes work atm requires nodes to register which attributes they want to access in advance, when cycles starts syncing the scene but before shaders are compiled.
SVM nodes can do this because their attributes are either hardcoded or can be read from DNA data beforehand. This is not possible with OSL getattribute variants. Even though most of the time you'd use a string literal to define the attribute, it is also possible to use string parameters and dynamically constructed strings, which would require actual evaluation of the shader to determine the requested attribute.
The only feasible way to support this afaict is to have either explicit user-requested attributes associated to the node, or to implement lazy loading of attributes during the render process (unlikely this would work). Possibly it could be implemented using OSL metadata, which would directly associate the requests with the OSL code instead of placing it in the Blender DNA.
Putting this on the ToDo list: http://wiki.blender.org/index.php/Dev:2.6/Source/Render/Cycles/ToDo
Quick mockup of how OSL metadata requests might work:
Ok then, thanks for the clarification.
