Cycles Baking and applyRotation issues #40156
6 Participants
Reference: blender/blender#40156
MacPro dualXeon, ATI HD 5870, OSX 10.8.5
hash
8904eaf
Applying rotation issue
Try this blend file, it demonstrates the issue.
https://dl.dropboxusercontent.com/u/24090090/ApplyBakeTest.blend.zip
Here's a request, it sounds rather as a feature but can be considered as a major bug.
Have two or three cubes on a plane. Add a second plane on top (to be the active for baking).
Try for normal maps.
OK. (I mean, bevel these cubes to have something to see on a nmap LOL)
Now, rotate these cubes a bit, select all, the last is the active plane on the top. Bake…
Wrong? because you did not apply rotation on objects first!
It goes worse now.
Use an empty and rotate the object by this empty.
Wrong baking again.
This isn't right. We shouldn't have to apply rotations and scale and etc. In fact we should avoid it in most cases.
An object has its own coordinates and we have to respect this.
By example, bake a nice object space normal map, apply it to the object, rotate the object. All fine. Apply rotation and the OS nmap is useless. (same when rotating in edit mode)
Added subscriber: @michaliszissiou
You are no longer supposed to apply rotation to any object. If that's not happening than it's a bug.
I'll check your file later. Does the same file bake well in Blender Internal?
The file bakes well in blender internal
Cycles render is still wrong, in the half an hour ago build hash
3557094
This bug is here, some time now.
Just reminding, the wrong object space I was getting, trying on a sculpt imported from zbrush.
Zbrush tends to rotate x 90º. Easy to not see it. So, wrong OS if not applying rotation. (Direct bake)
And completely wrong, when bake to active.
Lot of complains and failures of new users may be related to this.
Added subscriber: @mgiebler
Added my own test file created in latest BuildBot build
51fa66b
(win32 vs2013).Steps to reproduce: load sel_to_act_1.blend, click Bake, view the (correct) normal map on the right, switch to Cycles Render, click Bake again, compare.
Thanks for the sample file, that's a pretty good one.
Added subscriber: @motorsep
Sometimes it's not practical to apply location/rotation in the scene. You don't just bake final models that you won't ever touch again. There are iterations in the process and you will need to continue modeling/refining from the moment you left off to bake normal maps (as an example).
Why not to automatically create a copy of objects that are being baked, apply transforms to them, bake maps, delete copies afterward ? This way you end up with unmodified scene, and proper bake results.
@motorsep you misunderstood something. The idea of applying the transformations is only a workaround before we fix this issue. It's a bug and will be fixed.
Issue partly fixed, there is a remaining issue though: cycles_bake_sel_to_act_GSR.blend
If the highpoly object has non-uniform scale things don't work well.
This issue was referenced by
8d297394ba
Closed by commit
8d297394ba
.Changed status from 'Resolved' to: 'Open'
2bfc3debd9
Closed by commit
2bfc3debd9
.Added subscriber: @BartekMoniewski
2057a3a2fc
For the records, this is properly fixed now. No errors/warnings, it simply handles whatever transformation the selected objects have.
I had my tests. Lot of them.
So far, it works fine.
I also performed tests including arrays combined with curve deform. I also tested alt+S on the curve bezier.
Lot of deforms and rotations.
Cycles bakes them perfectly.
I believe it is fixed.
