Triangle fan bevel behavior #40722
Closed
opened 2014-06-20 03:36:16 +02:00 by Duarte Farrajota Ramos · 13 comments
Windows 7 64Bits
Broken: version 2.71 (sub 0), branch b'master', commit date b'2014-06-18' b'22:46', hash b'b49e6d0', b'Release'
Similar behaviour on 2.71 RC1
Of a triangle fan vertex the bevel/bevel modifier gives undesirable/unexpected behavior
Check screenshot or attached file Bevel_TriangleFan.blend
Of a vertex where a few edges meet, making a few triangles that form a 90 degree corner the bevel modifier gives a weird effect with a few extra faces{F94833}
**System Information** Windows 7 64Bits **Blender Version** Broken: version 2.71 (sub 0), branch b'master', commit date b'2014-06-18' b'22:46', hash b'b49e6d0', b'Release' Similar behaviour on 2.71 RC1 **Short description of error** Of a triangle fan vertex the bevel/bevel modifier gives undesirable/unexpected behavior **Exact steps for others to reproduce the error** Check screenshot or attached file [Bevel_TriangleFan.blend](https://archive.blender.org/developer/F94834/Bevel_TriangleFan.blend) Of a vertex where a few edges meet, making a few triangles that form a 90 degree corner the bevel modifier gives a weird effect with a few extra faces{[F94833](https://archive.blender.org/developer/F94833/Bevel_TriangleFan.blend)} ![TriangleFan.png](https://archive.blender.org/developer/F94831/TriangleFan.png)
Added subscriber: @DuarteRamos
Added subscriber: @mont29
Howard Trickey was assigned by Bastien Montagne 2014-06-20 08:23:38 +02:00
Member
This is not a regression; the code is acting as intended according to choices documented in http://wiki.blender.org/index.php/User:Howardt/Bevel .
The "expected results" diagram might be gotten by some combination of the choices "don't preserve angles" and "do partial vertex bevel". I agree that in the case illustrated, the "expected results" look better.
Will have to decide whether to expose more choices to the user, or somehow recognize this as a special case, or leave as is.
This is not a regression; the code is acting as intended according to choices documented in http://wiki.blender.org/index.php/User:Howardt/Bevel . The "expected results" diagram might be gotten by some combination of the choices "don't preserve angles" and "do partial vertex bevel". I agree that in the case illustrated, the "expected results" look better. Will have to decide whether to expose more choices to the user, or somehow recognize this as a special case, or leave as is.
I forgot to mention this is probably not a bug per-se, just regular behavior that I thought could use some improvement.
Just to be clear, on the example screenshot the "desirable" or "expected" behavior was hand modeled.
I forgot to mention this is probably not a bug per-se, just regular behavior that I thought could use some improvement. Just to be clear, on the example screenshot the "desirable" or "expected" behavior was hand modeled.
Member
Added subscriber: @beta-tester
Member
you can dissolve the inner edges of the fan, first. ([del]-key + "Dissolve Edges")
then add the bevel to the object to get the expected result...
i think the bevel algorithm is not able to figure out, what part of the object should be handled in what way - different users, different tastes of what the user expects.
you can dissolve the inner edges of the fan, first. ([del]-key + "Dissolve Edges") then add the bevel to the object to get the expected result... i think the bevel algorithm is not able to figure out, what part of the object should be handled in what way - different users, different tastes of what the user expects. ![Bevel_TriangleFan.blend.png](https://archive.blender.org/developer/F95116/Bevel_TriangleFan.blend.png)
Well that workaround seems to work pretty well, thanks for the tip
Added subscriber: @00Ghz
Would love to see more options for the bevel modifier. Like those found in C4D R15 . Although that's quite a lot of work I guess.
https://www.youtube.com/watch?v=x5G_EMc0M6Q
Especially that graph part would be cool.
Would love to see more options for the bevel modifier. Like those found in C4D R15 . Although that's quite a lot of work I guess. https://www.youtube.com/watch?v=x5G_EMc0M6Q Especially that graph part would be cool.
Member
Member
Added subscribers: @howardt, @JulianEisel
Member
Taking the liberty to close this as todo - there even is a workaround to get the desired result. @howardt, hope you're fine with that?
6 Participants
Reference: blender/blender#40722
