VSE separate images increases file size abnormally #41086
Closed
opened 2014-07-15 19:19:12 +02:00 by Ângelo Brandão Benetti · 14 comments
In official Blender 2.71, by spliting a strip with a sequence of 722 images with Separate images function bpy.ops.sequencer.images_separate(length=x)
the .blend file jumps from 600 Kb to something near 132 Mb, without any packed file.
It seems a bit exagerated compared to the same steps done in 2.70a, where it increases from 570 kb to 4.4 Mb, much more reasonable.
Scientific Linux (CentOS like)
Linux lajeado 2.6.32-431.20.3.el6.x86_64 #1 SMP Thu Jun 19 14:01:59 CDT 2014 x86_64 x86_64 x86_64 GNU/Linux
Graphics card: 0f:00.0 VGA compatible controller: NVIDIA Corporation GT200GL [Quadro FX 3800] (rev a1)
Broken: 2.71 hash: 9337574
Worked: 2.70a
In official Blender 2.71, by spliting a strip with a sequence of 722 images with Separate images function bpy.ops.sequencer.images_separate(length=x) the .blend file jumps from 600 Kb to something near 132 Mb, without any packed file. It seems a bit exagerated compared to the same steps done in 2.70a, where it increases from 570 kb to 4.4 Mb, much more reasonable. **System Information** Scientific Linux (CentOS like) Linux lajeado 2.6.32-431.20.3.el6.x86_64 #1 SMP Thu Jun 19 14:01:59 CDT 2014 x86_64 x86_64 x86_64 GNU/Linux Graphics card: 0f:00.0 VGA compatible controller: NVIDIA Corporation GT200GL [Quadro FX 3800] (rev a1) **Blender Version** Broken: 2.71 hash: 9337574 Worked: 2.70a **Short description of error** **Exact steps for others to reproduce the error** Based on a (as simple as possible) attached .blend file with minimum amount of steps
Added subscriber: @AngeloBenetti
Member
Added subscriber: @jta
Added subscriber: @mont29
I cannot reproduce that here (linux64), neither with official 2.71 nor current trunk, I’m always getting same results (6.8 Mo for about 150 images - which I found already rather high, tbh!).
Added subscriber: @Sergey
Please always attahc all files needed to reproduce the issue.
I can only think you've got really long sequence and separating it for a single frame, which leads to loads to individual strips. This would for sure bump file size dramatically.
Please always attahc all files needed to reproduce the issue. I can only think you've got really long sequence and separating it for a single frame, which leads to loads to individual strips. This would for sure bump file size dramatically.
@Sergey would you consider bump from 500k to 6.8M (from 1 strip to 150) the expected amount of increase mem? That would make about 40k per strip, sounds a bit high to me, tbh…
Also, I can have a look at that myself, if you want (just assign it to me in this case).
@Sergey would you consider bump from 500k to 6.8M (from 1 strip to 150) the expected amount of increase mem? That would make about 40k per strip, sounds a bit high to me, tbh… Also, I can have a look at that myself, if you want (just assign it to me in this case).
Bastien Montagne was assigned by Sergey Sharybin 2014-07-21 17:40:27 +02:00
40K indeed looks a bit suspicious. Definitely worth checking. Please go ahead :)
Also guess "uncofirmed" should be removed now?
Found the culprit - we copy everything from the old sequence into each new ones… including the stripdata, which for image sequences is an array with one item per image!
Following patch fixes this in the simplest way possible, not sure it would be considered good enough for master, Sergey?
P93: #41086
diff --git a/source/blender/editors/space_sequencer/sequencer_edit.c b/source/blender/editors/space_sequencer/sequencer_edit.c
index 973d6a9..dcf13db 100644
--- a/source/blender/editors/space_sequencer/sequencer_edit.c
+++ b/source/blender/editors/space_sequencer/sequencer_edit.c
@@ -1919,9 +1919,12 @@ static int sequencer_separate_images_exec(bContext *C, wmOperator *op)
 				strip_new = seq_new->strip;
 				strip_new->us = 1;
-				/* new stripdata */
-				se_new = strip_new->stripdata;
+				/* new stripdata (only one element now!) */
+				/* Note this assume all elements (images) have the same dimension, since we only copy the name here. */
+				se_new = MEM_reallocN(strip_new->stripdata, sizeof(*se_new));
 				BLI_strncpy(se_new->name, se->name, sizeof(se_new->name));
+				strip_new->stripdata = se_new;
 				BKE_sequence_calc(scene, seq_new);
 				if (step > 1) {
Found the culprit - we copy everything from the old sequence into each new ones… including the stripdata, which for image sequences is an array with one item per image! Following patch fixes this in the simplest way possible, not sure it would be considered good enough for master, Sergey? [P93: #41086](https://archive.blender.org/developer/P93.txt) ```diff diff --git a/source/blender/editors/space_sequencer/sequencer_edit.c b/source/blender/editors/space_sequencer/sequencer_edit.c index 973d6a9..dcf13db 100644 --- a/source/blender/editors/space_sequencer/sequencer_edit.c +++ b/source/blender/editors/space_sequencer/sequencer_edit.c @@ -1919,9 +1919,12 @@ static int sequencer_separate_images_exec(bContext *C, wmOperator *op) strip_new = seq_new->strip; strip_new->us = 1; - /* new stripdata */ - se_new = strip_new->stripdata; + /* new stripdata (only one element now!) */ + /* Note this assume all elements (images) have the same dimension, since we only copy the name here. */ + se_new = MEM_reallocN(strip_new->stripdata, sizeof(*se_new)); BLI_strncpy(se_new->name, se->name, sizeof(se_new->name)); + strip_new->stripdata = se_new; + BKE_sequence_calc(scene, seq_new); if (step > 1) { ```
This issue was referenced by 2e436173aa
This issue was referenced by 2e436173aae1ff715eb1d19aebbf7243ba4afc5c
Closed by commit 2e436173aa.
5 Participants
Reference: blender/blender#41086
