Cycles Fresnel nodes - broken gradients on objects with negative scale (final render only, not viewport) #41219
Closed
opened 2014-07-28 10:45:02 +02:00 by Tom Benedett · 12 comments
Windows 7 64-bit, GTX-580, AMD FX-4100, 8 GB RAM
Broken: Buildbot 2.71 698a9a2, and buildbot 2.71 b49e6d0
Worked: 2.70a official
On an object with negative scale, a cycles Fresnel or Layer Weight (just Fresnel output, not Facing) produces a sharp divide in final (but not viewport) renders, instead of a smooth gradient, as seen below:
The sphere on the left has x-scale -1; the one on the right is all positively scaled.
Take some smoothly-curving object, scale it by -1 along some axis (or all three, but not just two, that isn't broken;) and apply a material that uses a Fresnel mixing factor (default IOR/mix factor.) There will be a sharp divide where there should not be on the final render, but not in the viewport render,
Alternatively, see here:
Fresnel_and_Layer_Weight_Scale_Problem.blend
Try the two different Fresnel nodes and the Layer Weight, and observe that only Layer Weight works in final renders, but all three work in the viewport.
**System Information** Windows 7 64-bit, GTX-580, AMD FX-4100, 8 GB RAM **Blender Version** Broken: Buildbot 2.71 698a9a2, and buildbot 2.71 b49e6d0 Worked: 2.70a official **Short description of error** On an object with negative scale, a cycles Fresnel or Layer Weight (just Fresnel output, not Facing) produces a sharp divide in final (but not viewport) renders, instead of a smooth gradient, as seen below: ![Fresnel_and_Layer_Weight_Scale_Problem.png](https://archive.blender.org/developer/F99987/Fresnel_and_Layer_Weight_Scale_Problem.png) The sphere on the left has x-scale -1; the one on the right is all positively scaled. **Exact steps for others to reproduce the error** Take some smoothly-curving object, scale it by -1 along some axis (or all three, but not just two, that isn't broken;) and apply a material that uses a Fresnel mixing factor (default IOR/mix factor.) There will be a sharp divide where there should not be on the final render, but not in the viewport render, Alternatively, see here: [Fresnel_and_Layer_Weight_Scale_Problem.blend](https://archive.blender.org/developer/F99986/Fresnel_and_Layer_Weight_Scale_Problem.blend) Try the two different Fresnel nodes and the Layer Weight, and observe that only Layer Weight works in final renders, but all three work in the viewport.
Author
Author
Added subscriber: @moak
Sergey Sharybin was assigned by Bastien Montagne 2014-07-28 12:47:12 +02:00
Added subscriber: @mont29
Can confirm the issue with latest master as well. Sergey, this is your playground now. ;)
This issue had actually been fixed already in 9fcaac5 and eb8f85d. Please grab latest build from builder.blender.org and give it a try.
Let me know if the issue still exists for you, but for until then considering this issue is fixed.
This issue had actually been fixed already in 9fcaac5 and eb8f85d. Please grab latest build from builder.blender.org and give it a try. Let me know if the issue still exists for you, but for until then considering this issue is fixed.
Author
Nope, not fixed; it's still there as of the very latest Win64 buildbot version (7c9b8aa).
I hit F12 in the example file (using the new Blender version) and still get this image:
Nope, not fixed; it's still there as of the very latest Win64 buildbot version (7c9b8aa). I hit F12 in the example file (using the new Blender version) and still get this image: ![Fresnel_and_Layer_Weight_Scale_Problem_still_here.png](https://archive.blender.org/developer/F102799/Fresnel_and_Layer_Weight_Scale_Problem_still_here.png)
Changed status from 'Resolved' to: 'Open'
Indeed, for some reason it worked from the desktop..
This issue was referenced by bfaf4f2d0d
This issue was referenced by bfaf4f2d0d4e600f6f8e253033de2b05a93e3ec1
Closed by commit bfaf4f2d0d.
Reference: blender/blender#41219
