HDR image thumbnails cause blender to crash #42421
Closed
opened 2014-10-28 04:42:34 +01:00 by Daniel Stokes · 26 comments
Operating system: Windows 7 64 bit Graphics card: nvidea gtx 660 ti
Broken: 2.72 6c2ce7a and official blender 2.72b
Error Description: When viewing hdr images in the file browser with thumbnails enabled blender will crash. When an hdr is opened using the list view, opening the "browse image to be linked" drop down will crash blender.
Open new scene. Assign environment texture to world. Click open and change file display mode to thumbnails. Open a folder with an hdr image. Blender will crash.
If an hdr is loaded by not using the thumbnail preview mode then anytime the image datablock drop down menu is opened blender will crash.
**System Information** Operating system: Windows 7 64 bit Graphics card: nvidea gtx 660 ti **Blender Version** Broken: 2.72 6c2ce7a and official blender 2.72b Error Description: When viewing hdr images in the file browser with thumbnails enabled blender will crash. When an hdr is opened using the list view, opening the "browse image to be linked" drop down will crash blender. **Exact steps for others to reproduce the error** Open new scene. Assign environment texture to world. Click open and change file display mode to thumbnails. Open a folder with an hdr image. Blender will crash. If an hdr is loaded by not using the thumbnail preview mode then anytime the image datablock drop down menu is opened blender will crash.
Author
Author
Added subscriber: @DanielStokes
Member
Added subscriber: @lichtwerk
Member
cannot confirm, working fine here (linux).
maybe it's the specific file? (e.g. do the HDRs from openfootage.net work?)
cannot confirm, working fine here (linux). maybe it's the specific file? (e.g. do the HDRs from openfootage.net work?)
Added subscriber: @ideasman42
Please find the HDR file causing the crash and link to it.
Added subscriber: @SylvainMaziere
Tested on 2.72 and 2.72b on macosx 10.10: no problem, working fine too.
Author
I tried again with an HDR from openfootage and it didn't crash. I think it is related to the file size because all the HDRs that were crashing on my computer were 30 MiB and upwards.
Member
Just tried with 180MB HDR: no crash
however: this one did not get a preview image generated (plain document icon instead)
Just tried with 180MB HDR: no crash however: this one did not get a preview image generated (plain document icon instead)
Author
I opened the affected HDRs in photoshop and they were partially corrupted. I never noticed because if blender didn't crash when opening them then in the render they looked fine. Thank you for your help. Sorry for wasting your time.
Added subscriber: @kevindietrich
@lichtwerk: above 100 Mb no preview icons get generated
@DanielStokes: could you still link one of those corrupted files? Even if they are corrupted, I don't think Blender should crash.
@lichtwerk: above 100 Mb no preview icons get generated @DanielStokes: could you still link one of those corrupted files? Even if they are corrupted, I don't think Blender should crash.
Bastien Montagne self-assigned this 2014-11-07 09:13:05 +01:00
Let’s close that for until requested data are provided…
Author
Here is one of the files. https://dl.dropboxusercontent.com/u/1331174/GoldenGate_8k.hdr
I can confirm the segfault here on linux 64 with 5674ac9.
Some quick backtrace: asan_bt.txt
(NOTE) This also happens if you manage to load the image in e.g. an image texture node in Cycles and switch to Material view (preview and final render are fine).
I can confirm the segfault here on linux 64 with 5674ac9. Some quick backtrace: [asan_bt.txt](https://archive.blender.org/developer/F124505/asan_bt.txt) (NOTE) This also happens if you manage to load the image in e.g. an image texture node in Cycles and switch to Material view (preview and final render are fine).
Hrrmmmm… We read way too much data somehow here, this file is 8192 × 3153 for 45MB (which rather low, but its lower part can probably be compressed quite heavily even with RLE), and we overrun at line 1974: reading line 1974 starting at 42.882545MB from file start!
Note the file itself is valid afaict (imagemagick opens it e.g.).
Hrrmmmm… We read way too much data somehow here, this file is 8192 × 3153 for 45MB (which rather low, but its lower part can probably be compressed quite heavily even with RLE), and we overrun at line 1974: `reading line 1974 starting at 42.882545MB from file start`! Note the file itself is valid afaict (imagemagick opens it e.g.).
Grmlll… a (very rough) estimation says me this file should be around 75MB anyway… :/
Can you please give us application used to generate this HDR (comment says Blender???)? With parameters used, too…
Grmlll… a (very rough) estimation says me this file should be around 75MB anyway… :/ Can you please give us application used to generate this HDR (comment says Blender???)? With parameters used, too…
OK, so can confirm this file is definitively invalid (truncated, actually).
Will add some safeguard code to avoid crashing in such cases, nicer anyway.
OK, so can confirm this file is definitively invalid (truncated, actually). Will add some safeguard code to avoid crashing in such cases, nicer anyway.
This issue was referenced by cc0623ff6c
This issue was referenced by cc0623ff6c97c8bde5045f9aba1014f6dbd6bc8e
Closed by commit cc0623ff6c.
This issue was referenced by b0ea6aecb3582e223b85e0cc336b5afcc8600ede
This issue was referenced by a73b6c8d236d1b68dd80a748eeaed53d08f5a883
7 Participants
Reference: blender/blender#42421
